Small gaming htpc case help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 02-24-2012, 06:27 AM - Thread Starter
grumbledook's Avatar
Hi, I want to get rid of my big midtower and get a much smaller build instead. The problem is finding the right case. There's no rush as I want to do the build for when trinity is released in a few months.
It will be a htpc, but it does have to be gaming capable(within reason), so an expansion for a single slot card should be present. I could get an external blu-ray drive, but would prefer internal. A picopsu would be fine, as would an ordinary psu.
I'll be looking to get a better cpu cooler and some (better) fans where possible.
I've been looking at quite a few cases, and a few have caught my eye:
Chieftec FI-01B
Streacom F7C (Wesena also has variants of these)
Inwin bp655
Antec 310-150
I'm worried about the heat issue with these, and also the inwin one will make me have to get a smaller cpu cooler because of the 5,25' ... do full sized blu-ray players but that aren't as deep exist?
Any more suggestion on cases? I don't like the look of the cube ones, but I won't mind a m-atx case if it's not too wide (IE the psu on the side tends to do that). No need for a lcd display, but if it's not too glaring it won't matter.
Also, if there's a small itx case which can have such great airflow as I could overclock, there would be no need for an the expansion slot.
Thanks for any input.
grumbledook is offline
post #2 of 24 Old 02-25-2012, 01:26 AM
whentrumpetsfade's Avatar
The Silverstone PS07 has very good cooling for a small case and has front USB 3.0 ports
http://www.newegg.com/Product/Produc...82E16811163186
whentrumpetsfade is offline
post #3 of 24 Old 02-26-2012, 05:58 AM - Thread Starter
It is a nice looking case, and certainly doesn't look like cooling would be a big problem in it. But big is the actual problem nonetheless, just too big of a tower. Really looking more for a desktop one (the images of the other cases just were set upright, I wouldn't use them that way probably).
post #4 of 24 Old 02-26-2012, 08:47 AM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
Gaming = high powered graphic card, as much cpu as u can get = HOT = large fans = large heatshink <> Small case.
plus
People mostly want their htpc to be quiet.
Gaming rigs (because of paragraph#1) tend to be loud, unless by gaming you mean backgammon.
MrBobb is offline
post #5 of 24 Old 02-26-2012, 09:50 AM - Thread Starter
I don't agree with that at all. I don't mean needing to put a 7990 in there, nor playing ultra 1080p with all antialiasing and whatnot enabled. With good fans, heatsink and fancontroller it could be quiet enough when using it for other things.
post #6 of 24 Old 02-26-2012, 09:57 AM
assassin's Avatar
Quoted: 155 Post(s)
Liked: 261
Have you considered the Llano?
assassin is offline
post #7 of 24 Old 02-26-2012, 10:09 AM - Thread Starter
Yep, that's what I plan on using... or rather trinity which is the followup to llano. It should be out in a few months at most.
post #8 of 24 Old 02-26-2012, 10:12 AM
assassin's Avatar
Quoted: 155 Post(s)
Liked: 261
So use the integrated graphics. You said yourself you aren't trying to play max settings on any games.
assassin is offline
post #9 of 24 Old 02-26-2012, 10:17 AM - Thread Starter
Yeah, I suppose I might have to. Just would be nice to test out the crossfire with integrated ability, should give a good boost with a modest compatible card.
post #10 of 24 Old 02-26-2012, 12:23 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
Do you care if it is an small upright traditional case design vs a layflat component like case?
Mfusick is offline
post #11 of 24 Old 02-26-2012, 12:54 PM - Thread Starter
Would prefer layflat, but depends on the size.
post #12 of 24 Old 02-26-2012, 12:58 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
Whats your max size or dimensions?
What is your max budget?
Mfusick is offline
post #13 of 24 Old 02-26-2012, 01:43 PM - Thread Starter
Less than 300mm tall I guess, and preferably less than 400mm wide (preferably much less on both :P)
Up to around 300$ on the case.
post #14 of 24 Old 02-26-2012, 01:49 PM
assassin's Avatar
Quoted: 155 Post(s)
Liked: 261
I think this is a winner.
$50.
Case Dimensions (mm): 62(H) x 190(W) x 196(D)
Optional System Fan(s): 40 x 40 Side *4 or 60 x 60 Top *2
assassin is offline
post #15 of 24 Old 02-26-2012, 02:16 PM - Thread Starter
Definitely a small and cheap option.
Got any experience with the t3500 case also from morex?
Also quite liking the look of the lian-li q09.
post #16 of 24 Old 02-26-2012, 02:22 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
My favorite smaller budget case is this one:
http://www.newegg.com/Product/Produc...82E16811162059
I recently bought a few diffferent ones and this one impressed me the most.
Much more so- even over brand names like COOLERMASTER and Thermaltake, Rosewill and ANATECH and such. (yes I actually bought all these and compared them)
It's $29 and comes with a 500 watt PSU.
It's a solid option for low budget build.
It's black high gloss and attractive. The quality is more than acceptable given the price.
Mfusick is offline
post #17 of 24 Old 02-26-2012, 02:24 PM
whiteboy714's Avatar
That thing is pretty ugly. He said his budget is up to $300 so I'm thinking he wants something nice.
whiteboy714 is offline
post #18 of 24 Old 02-26-2012, 02:38 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
It's a pretty simple black gloss plastic all around. Actually looks different in real life. You don't notice the front fan much at all unless it's dark.
$300 is a long ways from $30. Lol. I missed that part if that is true.
My case was $349. Long way from what he is looking for though.
No need to spend that kind of money on a small case IMO.
Mfusick is offline
post #19 of 24 Old 02-26-2012, 02:48 PM - Thread Starter
Well I will be much happier spending 50 bucks over 300 if I'm happy with the 50$ option. But I don't think that either the microtower you posted, or the morex case are too ugly. The morex one is tiny so it's easy to hide anyway, and the tower wasn't very glaring apart from the lights which is easily removed.
Which case did you get?
post #20 of 24 Old 02-26-2012, 02:57 PM
Tizi's Avatar
I have this case for my main HTPC. Specs: i3-2100, 4 GB Kingston 1600 RAM, 60 GB OCZ Agility 3, MSI H67 mobo, Asus GT 440 video card, Samsung Blu-ray player, card reader. Stays very cool.
http://www.in-win.com.tw/US/products...2&model_id=248 Inwin BK644
You can have it horizontal or vertical. Mine lays horizontal.
Tizi is offline
post #21 of 24 Old 05-01-2012, 05:18 AM
kevinbright's Avatar
Does this case come with a memory card reader? I noticed your post mentions a card reader, but I havent seen reference to a card reader on any of the specs. Thanks,
Kevin
kevinbright is offline
post #22 of 24 Old 05-01-2012, 07:54 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
This one has a low-profile slot, comes with a 120W internal PSU and can be cooled fairly well with up to 4 x 80mm fans:
http://www.minicase.net/product_E-I7.html
If you Google 'E-I7 HTPC' you can find it for sale in the US. There is also a thread here with a build done with this case, pictures, etc.
StardogChampion is offline
post #23 of 24 Old 05-01-2012, 12:48 PM - Thread Starter
Oh, forgot to update the thread. I decided to go for the inwin BP655, which I regret a little. The case fan is very noisy(going to replace it tho), and the psu fan could be more quiet too. I've fitted it with a g850 and a geforce 210 that I had lying around. I'm going to chuck a 7750 in it once the low profile gets available. Apart from the fan noise, the case is behaving quite alright. Tizi's option would probably have suited me better tho.
I'm still on the market for another case tho as I decided to get rid off another pc (old optiplex 620 one). That E-17 is very slick looking, definitely going to keep it in mind.
post #24 of 24 Old 05-01-2012, 01:36 PM
Quoted: 93 Post(s)
Liked: 160
It's the little sparkly things in the picture, isn't it?
Reply Home Theater Computers
