HTPC Build - Assassin Style - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 44 Old 03-02-2012, 10:12 AM
Zon2020's Avatar
Originally Posted by Superman2 View Post
Nice build.
I might copy this actually. There's no problem adding a tv tuner in there, right? Room wise?
I added a Hauppauge Colossus in mine without a problem. I assume most tuners would fit without any issue.
Zon2020 is offline
post #32 of 44 Old 03-02-2012, 12:08 PM
ozer19's Avatar
Great build and great pictures. I am a complete newb here about this stuff. I was going to open a thread, but instead of opening it, I'd rather get answers inside others' without increase the thread numbers.
We have a Costco bough HP laptop with an HDMI output that I have been using to connect to my Home Theatre. I think I do not get the same picture quality as I expected. Can this be because of the cheap screen card that they used in the laptop?
If that is the case, I would like to build a dedicated HTPC like the OP did here. What kind of screen card is suggested to watch BD quality .iso or .mkv files that I have? I also have 3D projector so I am not sure that requires a different card or not.
Should I build one instead of using the laptop? Sorry for the off topic, but I thought it is a little relevant. I love thr build here.
ozer19 is offline
post #33 of 44 Old 03-02-2012, 01:18 PM
Zon2020's Avatar
What CPU and graphics does your laptop have?
If you got that laptop in the past year, I wouldn't necessarily assume your problem is with your hardware.
Zon2020 is offline
post #34 of 44 Old 03-03-2012, 07:58 AM
ozer19's Avatar
It is an HP Pavilion dm4 Laptop with:
i5 2.40GHz
Intel(R) HD Graphics (this is all i could find in the device manager)
ozer19 is offline
post #35 of 44 Old 03-03-2012, 11:50 AM - Thread Starter
nexus99's Avatar
i5 2.40GHz
I would guess that hardware is just as good as the hardware in the thread build.
nexus99 is offline
post #36 of 44 Old 03-04-2012, 01:26 AM
scarpenter002's Avatar
Nice build and nice write up. I have a GD05 sitting at home waiting for me to get home and assemble it. I will also be using Assassin's guide to configure my setup. Can't wait to document it upload it here on AVS.
CIH Wannabe...one step at a time
scarpenter002 is offline
post #37 of 44 Old 03-04-2012, 06:09 AM
assassin's Avatar
Quoted: 81 Post(s)
Liked: 242
Great! Post a few pics if you can!
assassin is offline
post #38 of 44 Old 03-04-2012, 09:52 PM - Thread Starter
nexus99's Avatar
Updates:
My IR receiver is in the US. Should be here in a day or 2. A remote should make everything totally user friendly.
I just ordered a serial port bracket so I can control my RussSound amp. It looks like it will fit the header on the system board.
I am going to upgrade XBMC to the newest RC for a try for HD audio. I hope it preserves my settings ;-)
nexus99 is offline
post #39 of 44 Old 03-05-2012, 01:47 AM - Thread Starter
nexus99's Avatar
Just vegged out and watched 2 movies on the system. They are just beautiful.
Also added some updates into the first few posts.
nexus99 is offline
post #40 of 44 Old 03-05-2012, 02:30 AM
Originally Posted by nexus99 View Post
Updates:
Forgot to order my CIR until I saw your comment above, so went to order and the only vendor I have found that provide these, is back ordered until April. What a bummer. Fortunately I have a Lenovo mini wireless keyboard/trackball to use until I can get this.
Cheers,
Scott
post #41 of 44 Old 03-05-2012, 02:37 AM - Thread Starter
nexus99's Avatar
Try on E-Bay. Thats where mine is coming from. Shipping from China.
nexus99 is offline
post #42 of 44 Old 03-05-2012, 03:18 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
looking good
Mfusick is offline
post #43 of 44 Old 03-18-2012, 03:36 AM - Thread Starter
nexus99's Avatar
Working on getting my Harmony One all set up now. Mostly done but working out a few snags. Created a thread about it specifically.
nexus99 is offline
post #44 of 44 Old 06-28-2012, 04:21 PM - Thread Starter
nexus99's Avatar
Some updates.
Got my Harmony working... albeit its a little herky jerky.
I decided that, for me, having a seperate file server and HTPC was really over kill as that I only have about 1 TB of data/audio/video and its not really growing. So I pulled the 3 disk raid array out of my WHS (3x 2TB HDs and a RAID 5 controller) and transplanted them into my HTPC. I had to put the 3rd disk in the optical bay... but it was empty and I have no plans to put an opitcal disk player in this computer.
Everything came up and works like a champ!
I could not notice any difference in the noise level of the PC either!
So now this box is running XBMC, Casatunes, and is a 4 TB RAID 5 based file server for the whole home.
I also installed VirtualBox on it... but I haven't played with that too much.
nexus99 is offline
Reply Home Theater Computers
