Do Window MCE 7 plugins work with the XBOX 360? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-24-2012, 08:46 PM - Thread Starter
FHT123's Avatar
Quick question....If I download WMCE7 Plug-Ins....will they show up on the XBOX 360 when I use it as an extender?
FHT123 is offline
post #2 of 4 Old 02-25-2012, 08:14 AM
jonathanrn's Avatar
Some of them do and some of them don't. It mainly depends on the resources used in the plugin. I, for example, have a Hulu integration plugin, that will close Media Center and open up Hulu for Desktop. This obviously won't work on an extender. Other plugins work perfectly. It's a case-by-case basis.
Jonathan
jonathanrn is offline
post #3 of 4 Old 02-25-2012, 06:37 PM - Thread Starter
FHT123's Avatar
Got it, thanks. Sorry I should have been more specific. I was referring to plugins that are completely integrated into WMCE and do not open from the desktop. IE - A weather app, etc.
FHT123 is offline
post #4 of 4 Old 02-25-2012, 10:51 PM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
If the plugin is based/dependent on Flash or Silverlight it won't work. Other than that it should work.
staknhalo is offline
Reply Home Theater Computers
