X-FI and Windows 7 setting for analog HTPC output help needed.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 02-25-2012, 05:42 AM - Thread Starter
Luis Gabriel Gerena's Avatar
Quoted: 94 Post(s)
Liked: 63
Hello!
I get confused about how to setup my speakers in Windows and in the X-FI control panel to make sure first that I am not setting double crossovers or so.
For example, do I go to the Windows Playback devices and change speakers to FULL Range but then in the X-Fi THX control panel check the Bass Management option so that at 80HZ the bass is routed to my sub?
I am using the analog output of this x-fi prelude btw as my HK receiver does not decode Dolby True nor DTS HD.
Mario Lemieux is GOD!
Go Pens!!!
Aguante Boca!!!
If dolphins are so smart...why do they live in igloos?
Luis Gabriel Gerena is offline
Reply Home Theater Computers
