Backing up BR..should I go with Server or Disc ? - AVS | Home Theater Discussions And Reviews
post #1 of 4 Old 02-26-2012, 05:00 PM - Thread Starter
KINGOFOOTBALL33's Avatar
Cost seems to benefit Multi TB server in the long run.
However
1. Are there any devices (wdlive , micca ?) that would stream a BD backup and retain menus and audio ?
2. Would there be ANY pq drop on a streaming option ?
KINGOFOOTBALL33 is offline
post #2 of 4 Old 02-26-2012, 05:52 PM
kegobeer's Avatar
1. Yes. The Dune players support full BD menus. I don't know about the rest, but I know the WD Live series do not support BD menus at all.
2. No. The only quality drop would be from a low quality rip, which doesn't happen if you rip the entire disc to BDMV folder structure or ISO.
kegobeer is offline
post #3 of 4 Old 02-26-2012, 07:53 PM
lockdown571's Avatar
Liked: 60
There's actually a separate forum for media servers and content streamers here. Anyways, there are a few others that play back menus like the Popcorn Hour A-300, but the Dunes are widely regarded as the most reliable.
There will be no loss in quality, although you absolutely need to use wired network connections.
lockdown571 is offline
post #4 of 4 Old 02-27-2012, 12:45 AM - Thread Starter
hmmm Going to have to look into non wireless option. A quick look made me realize the bandwidth needed.
Its a shame BD50 are still so pricy per disc. I may go unelegant and just run an HDMI from pc to tv when needed then tuck away when not in use.
Reply Home Theater Computers
