Offer suggestions for HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-27-2012, 01:00 PM - Thread Starter
knight_40k's Avatar
This is sort of a two part thread, hardware advice and software issue.
I know my system is overkill for my application being as I ONLY watch movies/tv on this system and have no plans to change that. I'm wondering if there are any component changes I should make to have things run silent/cooler. I already disconnected my two 80mm fans at the rear due to noise. Should I remove them completely to atleast allow open airflow? It usually only runs for 3-4 hours at a time.
Case: Thermaltake Mozart Media Lab
Mobo: MSI 890GXM-G65
CPU: AMD Phenom II X2 560 3.3Ghz Black Edition
CPU Cooler: Zalman CNPS8000A
GPU: Onboard HDMI Radeon 4290
RAM: Kingston 8GB DDR3 1333 (2x4GB)
HDD:
Hitachi Deskstar 80GB OS Drive 7200 SATA2
Western Digital Caviar Green 1TB 5400 SATA2
Western Digital Caviar Green 2TB 5400 SATA2
PSU: Seasonic SS-460FL 460Watt
Disc Drive: Liteon BD Rom (iHOS104)
OS: Windows 7 Pro 64-Bit
Other Accessories:
HP eHome USB IR Transceiver
Startech 5.25" SATA Hot Swap for 3.5" Drive
At the moment I do not care about HD Audio I can always add a Radeon 5450 or newer down the road if I want DTS MA/Dolby TrueHD.
My main issue I was having problems with XBMC and stopped using it for about a year but I'd like to go back to it and hope issues have been fixed.
The issue was some files would not play period and others would have video but no audio. I found this odd being as VLC could play everything just fine. All files were MKV. The audio issue was odd too because if I changed XBMC settings and un-clicked dolbly/DTS support and had 2ch operation it worked fine, but I shouldn't have to do that. But lets go back even further, I was originally having this problem when using WinXP but I later changed to Win7 and the previous files that has issues suddenly worked. However, a few weeks later as I added some new files as tv series continued to air, those files started gaving me the same problem. And again, everything worked fine in VLC. I'm not sure was version of XBMC was I was using but all of my drivers were up to date. Has anyone else experienced this problem? What version are you using now?
knight_40k is offline
post #2 of 4 Old 02-27-2012, 01:10 PM
lovekeiiy's Avatar
Liked: 30
sounds like your settings may have been off just a bit in XBMC. You need do to go through and check all the settings for your video and audio in XBMC; I find this true with Plex as well.
VLC tends to be a lot more lenient file discrepancies than the players for XBMC, Plex, Boxee, and so forth.
As for noise, I would get the largest fans I could, and the ones that are suppose to be silent. Less rotations, less noise. Otherwise, go everything heat sinks. Heck, just ditch the case and you should have plenty of air.
lovekeiiy is offline
post #3 of 4 Old 02-27-2012, 02:49 PM
Gary Quiring's Avatar
What is the XBMC PC hooked up to for a receiver? Does the receiver support DTS/DD? Also were you using a TOS connection or just stereo plugs?
Gary Quiring is offline
post #4 of 4 Old 02-27-2012, 11:10 PM - Thread Starter
knight_40k's Avatar
I'm using an Onkyo 707 via HDMI. All drivers are up to date.
Reply Home Theater Computers
