HDMI /DVI (PC) input samsung - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-28-2012, 09:32 AM - Thread Starter
franky932's Avatar
Quoted: 30 Post(s)
samsung hdmi input
why the HDMI/DVI (for PC) input can not handle sound like other's hdmi input
alll my hdmi inputs are connected...so i have to pass a long audio cable SPDF (optical )from my PC to my amplifier..............
or next to the the HDMI/DVI (for PC) input ,a little cable in the 1/8'' input.
hdmi input with no sound :what is the purpo
Sony 2015 STR-DN 1060 A/V receiver+2 X150 WATTS RMS JBL , 2 REAR SURROUND 100 Watts RMS Mordaunt Short + Orage75Watts RMS SUB
franky932 is offline
post #2 of 9 Old 02-28-2012, 12:08 PM
Quoted: 49 Post(s)
Liked: 37
I am not sure your premise (that it cannot handle sound) is correct.
Roussi is offline
post #3 of 9 Old 02-28-2012, 01:49 PM - Thread Starter
franky932's Avatar
Quoted: 30 Post(s)
i have 4 hdmi input total.
1 is named hdmi/dvi........in the book and on the HDTV Samsung . no sound pass trough(t) because there is a 1/8 in audio IN beside that input.
post #4 of 9 Old 02-28-2012, 01:50 PM - Thread Starter
franky932's Avatar
Quoted: 30 Post(s)
must connect audio from PC too.
i try it no sound
so why is that? reason?
post #5 of 9 Old 02-28-2012, 04:27 PM
mcantu1's Avatar
that sound input is for using DVI on that port...because DVI doesnt carry sound. if you have and nvidia card, make sure that the output in the control panel is hdmi-audio and not hdmi-no audio
mcantu1 is offline
post #6 of 9 Old 02-28-2012, 05:40 PM - Thread Starter
franky932's Avatar
Quoted: 30 Post(s)
i know that.........the 3 other HDMI IN have sound with my HDMI OUT of my PC.
Question: why HDMI/DVI can not pass sound
what special have that INPUT.
post #7 of 9 Old 02-29-2012, 01:10 PM
Quoted: 49 Post(s)
Liked: 37
Did you try a different input setting on that hdmi?
I forgot what the options were, but remember I had to change mine to connect the htpc.
Roussi is offline
post #8 of 9 Old 02-29-2012, 01:54 PM
tlniec's Avatar
Not sure what exact Samsung TV you have, but you may have to rename the input to just "PC". On my PN50B650, naming it "PC" is required to have input from the HTPC work correctly. Never tried "HDMI/DVI" so I can't comment on whether that kills the sound. But I did try "STB" for the name once, and found I was getting black crush (figure only with "PC" input will it handle the reference levels correctly).
tlniec is offline
post #9 of 9 Old 02-29-2012, 03:09 PM
Quoted: 49 Post(s)
Liked: 37
yes, that was it, "PC" rather than "STB" (on a PN50c490).
Roussi is offline
Reply Home Theater Computers
