Hooked up PC to Plasma... burn in? - AVS Forum | Home Theater Discussions And Reviews
Old 03-01-2012, 03:37 PM - Thread Starter
CaseLogic's Avatar
Quoted: 18 Post(s)
I hooked up my old PC to my 60" Panasonic plasma. Looks good, but I'm worried about burn in. Is there anything I can do this to make it much less of an issue? I turned the taskbar to autohide and I made my background a slideshow that changes frequently. Screensaver goes on after 2 minutes.
Generally speaking, I'll probably use this for media playback like videos. However, i'm worried about when I do a session of internet surfing on Chrome and that the application UI will cause some IR or even burn in.
Any tips tricks or ideas?
CaseLogic is offline
Old 03-01-2012, 03:40 PM
pokekevin's Avatar
Liked: 102
I use my d6500 for 70% pc and haven't had mkuch issues. Any ir goes away after watching a film.
pokekevin is offline
Old 03-01-2012, 03:43 PM
winterescape's Avatar
Valid concern with any stationary objects (logo, tickers, etc...) I make sure the screen goes black after a min or two of inactivity. Also, newer sets are less prone to this and it is much less an issue after the plasma has over 1K hours on it.
winterescape is offline
Old 03-01-2012, 05:21 PM
xfett's Avatar
I have a Panasonic TH - 42PX60U which has well over 1k hrs, IR and burn in are still a problem.
"Man, I told you we shouldn't have shot Niedermeyer"
xfett is offline
Old 03-01-2012, 05:55 PM
cshaw88's Avatar
How old is your plasma? I have a 6 year old 65" panasonic plasma and it seems very resistent to burn in. I've played countless hours of xbox games on it and never had any burn in. The crosshair from FPS games stays in the same place the entire game, still no burn in.
An older plasma my be in your favor in this case. I believe burn in is more of a problem when a plasma is brand new. If you're really concerned you can reduce the contrast, but I doubt you'll have any problem to begin with.
cshaw88 is offline
Old 03-01-2012, 07:04 PM
xfett's Avatar
Mfg date on my Panny is '05 and after several hours of Xbox or PS3 games there is major IR. Usually takes several hours of tv watching to remove it.
xfett is offline
Old 03-01-2012, 07:39 PM
rockytt's Avatar
Ditto for my '10 Sammy - major IR
rockytt is offline
Old 03-01-2012, 08:22 PM
Randy Mathis's Avatar
I see brief periods of burn in on my plasma. It goes away a minute or so after the picture changes.
To help with the problem I have the taskbar set to hide, I don't have icons on the desktop and I have my background picture set to change every minute.
The biggest problem is if I let the picture sit on the windows media center menu for too long or if I pause a program for too long. The "bugs" that television stations have on the picture and tickers also bother me.
All animals are created equal, but some animals are more equal than others.
Randy Mathis is offline
Old 03-01-2012, 08:46 PM
hogues's Avatar
Quoted: 73 Post(s)
Liked: 51
I have my screen saver set to constantly play a slideshow of my photos, which helps avoid the problem.
hogues is offline
Old 03-02-2012, 07:50 AM
cshaw88's Avatar
Maybe I just got lucky with my plasma (built in 06). I was actually surprised when I bought it that ir never occured. I assumed panasonic had mostly solved the ir problems.
cshaw88 is offline
Old 03-02-2012, 11:48 AM
Suntan's Avatar
Quoted: 75 Post(s)
Liked: 108
I wish my 7 year old plasma would suffer from noticable burn in so I could justify replacing it.
Seriously, adjust your settings properly so that your TV isn't sitting there in "torch" mode and you should be fine.
-Suntan
Suntan is offline
Old 03-02-2012, 12:39 PM
rockytt's Avatar
Already did and do - brightness and contrast are both running around 40% and get still get pretty good IR - and all I do is watch movies, no surfing at all...
rockytt is offline
Old 03-02-2012, 01:24 PM
stm69's Avatar
Quoted: 17 Post(s)
Liked: 26
Definately please be careful. Not only is IR or burn-in possible, so is the possibility of uneven phosper wear. I screwed up my original Pioneer 5020 with this. Plasma was setup as secondary monitor that duplicated the primary in 4:3 mode, so the background was in 4:3 with black bars on the plasma. Used a screensaver etc to avoid burn-in, but imagine my horror after a few weeks when I watched something in full screen and the black bar area was substantially brighter than the middle. It never did go away completely
stm69 is offline
Old 03-02-2012, 07:08 PM
BBrinks's Avatar
I think some people are confusing burn in with image retention. As long as you're careful with it and switch up what you watch you'll be fine. I'd avoid playing espn or something similar with bright static logos for hours on end otherwise you'll get some IR that can take some time to go away. You're always going to get some IR but it not as much of an issue on newer sets as long as you don't abuse it.
Most of all, just enjoy your set and don't get paranoid about burn in otherwise you'll think about it whenever you're watching something.
BBrinks is offline
Old 03-02-2012, 10:00 PM
xfett's Avatar
Ya IR is always gonna be there no matter what people say torch mode or not and burn in is almost always an extreme case of misuse or neglect.
xfett is offline
