WMC performance issues with dual displays - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-04-2012, 03:14 AM - Thread Starter
docprego's Avatar
I have a powerful PC that I use as my primary PC and HTPC.
i7-2600
8GB RAM
ATI HD6770 1GB DDR5
1.5TB 7200 RPM HD
2.0TB 7200 RPM HD
Dual Blu-ray drives
This computer feeds two 23" 1080p displays. One of them is for web surfing and productivity and the other is exclusively used to view Digital cable in Windows Media Center from a Ceton InfiniTV card.
Because of the "feature" where WMC captures your mouse pointer on the secondary display (it cannot leave the WMC window) I use a utility called the Maxifier to free my mouse pointer. It works great except for one nagging problem: sluggish performance. If I run WMC on my external display in full screen without the Maxifier, the mouse is captured but the performance of WMC is flawless. There is no stutter and everything is buttery smooth. The minute I use the Maxifier WMC seems to struggle quite a bit. I know I can simply stop using the Maxifier but I love what it does. I have found a solution but it's not ideal. If I disable Windows Aero by selecting one of the basic themes, performance of WMC on my secondary display while using the Maxifier returns to normal. The problem with this is that disabling Aero eliminates many of the outstanding features of Windows 7.
So I guess what I am asking is, is there any way I can run WMC full screen on my secondary display without capturing the mouse and without experiencing sluggish performance?
My Ridiculously Inexpensive Dedicated Kick *** Home Theaters!
RIDKAHT <The Original>
RIDKAHT <<The Sequel>>
RIDKAHT <<<Part III>>>
docprego is offline
post #2 of 7 Old 03-12-2012, 05:19 PM - Thread Starter
docprego's Avatar
For anyone else struggling with this, I have made some very positive progress. Instead of completely disabling Aero and losing all of the features that come along with it, I have found a better solution. If I disable transparency while still leaving Aero enabled, the sluggishness I have experienced goes away. The best part is that I don't miss transparency at all.
docprego is offline
post #3 of 7 Old 03-13-2012, 10:54 AM
JoshDorhyke's Avatar
FYI, hitting the Windows key will release the mouse. But, if you minimize or quit the other program it can jump back. I tend to click on a Windows Explorer or something I just leave up in the background when doing that.
Do you have remote commands feeding through to WMC or anything like that?
JoshDorhyke is offline
post #4 of 7 Old 03-13-2012, 04:35 PM - Thread Starter
docprego's Avatar
Thanks, I am aware of the Windows key work around but it is not an acceptable solution IMO. I tend to access my Media Center window a lot to change channels and perform various tasks. It is very annoying to have to press the Windows key every time I need to free up my mouse. The Maxifier works perfectly to fix this but has resulted in slowdown up until now. Disabling transparency has really done the trick for me.
docprego is offline
post #5 of 7 Old 03-14-2012, 06:31 PM
garnuts's Avatar
Quoted: 79 Post(s)
Liked: 57
Thanks for the tip on disabling transparency. I've been using Maxifier so I wouldn't loose mouse focus for a few years on my triple-monitor desktop set-up.
Most TV programming was decent picture quality full screen using Maxifier. However, sports was almost un-watcheable because of the jitter. Now I know I can just disable transparency temporarily to watch sports
Living Room: Denon X4000, XPA-5, Polk RTiA9, CSiA6, RTiA3-wides, FXiA4, OWM3, SVS PC12+, 4 Shakers, Epson 5030, VApex 92”, Sony XBR9 52”, PS3, Xbox 360, Darbee, Harmony 1.
Bedroom: Denon X2000, Polk: RTiA3, CSiA4, RTiA1, SVS SB12-NSD, Sony XBR-55X850B, Sony BPD-S590, Xbox 360, RPi2-RasPlex, Darbee, Harmony 510.
Home Office: Onkyo 707, Polk: LSiM 703, LSiM 704, Monitor 70, Yamaha SW315 x 2, Turntable, Triple Monitors, Harmony 610.
garnuts is offline
post #6 of 7 Old 03-19-2012, 07:32 PM - Thread Starter
docprego's Avatar
Just curious if you actually tried this yet? What was your experience?
docprego is offline
post #7 of 7 Old 03-20-2012, 07:24 AM
garnuts's Avatar
Quoted: 79 Post(s)
Liked: 57
Yes, I've tried it a few times watching basketball. Disabling transparency is a very noticeable improvment with much less picture stutter/jitter in sports programming. Even the information crawl at the bottom of the screen is smooth now, where it was very jerky before. The picture is not completly smooth, but much improved.
Gary
garnuts is offline
Reply Home Theater Computers
