HD audio out of XBMC Yes! Nope. Not for me. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-04-2012, 04:06 PM - Thread Starter
digital desire's Avatar
So I downloaded the newest XBMC containing the HD audio parts. I can (and have) selected the proper outputs like DTS MA and Dolby True, yada yada.
But, at the bottom of the same page where you select hdmi output device, my display (new sharp 70" 733) shows up, not my receiver. I think this is the reason I can not get DTS HD master audio.
How can I get it to see my Yamaha 867?
I can select different audio streams on the sound menu. Using the Dave Mathews/ Tim Reynolds as a reference.
The disc has three audio tracks, a 2.0, dolby digital, and DD true.
When I select between the three streams, the two DD tracks play the same on the receiver.
I am using the gigabyte/I3 combo.
Lot's of low rent stuff stacked up into a medium rent pile.
digital desire is offline
post #2 of 13 Old 03-04-2012, 04:20 PM
assassin's Avatar
Quoted: 132 Post(s)
Liked: 254
Change the "pass through" option on your AVR. It is sending the HDMI signal to the HDTV because that is what you have told it to do. Tell it you want it to decode the signal instead.
assassin is online now
post #3 of 13 Old 03-04-2012, 04:38 PM - Thread Starter
Thanks Assassin, a step in the right direction. I changed the pass thru off, (thought that was just for when the avr was off!) and now I can select the avr in the list on the menu. I powered down everything, and re-booted the computer to make sure it all set.
However, still can not get Dolby true, no matter what audio stream I select!
post #4 of 13 Old 03-04-2012, 04:39 PM
assassin's Avatar
Quoted: 132 Post(s)
Liked: 254
Use mediainfo and check that your file actually has TrueHD.
post #5 of 13 Old 03-04-2012, 04:51 PM - Thread Starter
Well, thanks once again. I downloaded that app, pointed it to the concert, and found that it says it contains three streams, on the top block, but in the breakdown of the streams, it only shows two, a stereo one and a 6 channel 640kbps, 48khz 16 bits 6 channels, ac3.
Hmmm. I take it that does not describe true hd? I ripped with makemk5. Something I did wrong ripping my concert collection?
post #6 of 13 Old 03-04-2012, 04:53 PM
assassin's Avatar
Quoted: 132 Post(s)
Liked: 254
Use the program mediainfo. If it doesn't say TrueHD then it doesn't have TrueHD.
That file has Dolby Digital. Not TrueHD.
post #7 of 13 Old 03-04-2012, 06:48 PM - Thread Starter
Well what did I do wrong with makemkv to lose the HD audio????
post #8 of 13 Old 03-04-2012, 06:50 PM
assassin's Avatar
Quoted: 132 Post(s)
Liked: 254
You didn't choose the correct stream/audio option. Usually its the largest option but sometimes its hard to tell.
This is assuming, of course, that the bluray you are using has a HD Audio option for you to actually choose.
post #9 of 13 Old 03-04-2012, 08:48 PM
nexus99's Avatar
I am about to go down this path on my new HTPC too.
nexus99 is offline
post #10 of 13 Old 03-04-2012, 09:19 PM - Thread Starter
Gotcha. Deleted and re-ripping as I type. I found the check box for the hd, and it was not checked. I have about 50 bd's to re-do!
post #11 of 13 Old 03-05-2012, 06:37 AM
Calcvictim's Avatar
Before doing that you could rip one and see if the difference is significant or audible at all to warrant so much work.
Calcvictim is offline
post #12 of 13 Old 03-05-2012, 08:06 AM
Veeper's Avatar
Originally Posted by calcvictim View Post
before doing that you could rip one and see if the difference is significant or audible at all to warrant so much work.
Blasphemy!
Veeper is offline
post #13 of 13 Old 03-05-2012, 08:15 AM - Thread Starter
I know what your saying....I've seen the site that had professional engineers (maybe the DTS site itself?) that could not notice a difference between the two. I am not going to rush and spend a lot of time switching over, but when I have a few minutes, rip another one sort of back burner deal.
Nice now that I know it works. It may be more of a mental thing.
I agree, it may also be BLASPHEMY!
Reply Home Theater Computers
