My HTPC - is it usable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-06-2012, 08:39 PM - Thread Starter
FHT123's Avatar
I have a Dell XPS400 that is about 6 years old. It is a Pentium D (Dual Core), 2.8 Ghz, 4 GB DDR2 Ram, with Windows 7 loaded on it. Will this work for a HTPC? I have bought a HD Homerun to use with my OTA feed.
FHT123 is offline
post #2 of 8 Old 03-06-2012, 09:00 PM
assassin's Avatar
Quoted: 83 Post(s)
Liked: 244
AGP or PCI video card?
assassin is online now
post #3 of 8 Old 03-06-2012, 10:20 PM
rdunnill's Avatar
The XPS 400 is PCI Express.
Blu-ray: 50+
HD-DVD: 23
DVD: 600+ and lost count
rdunnill is offline
post #4 of 8 Old 03-06-2012, 10:55 PM
Mac25's Avatar
Quoted: 14 Post(s)
yes it will work, at present i use an old 865 chipset P4 ht 3.0 with agp card and 1 gb ddr, win 7 32bit, it works well, br is left for standalone player.
Mac25 is offline
post #5 of 8 Old 03-06-2012, 10:57 PM
erickotz's Avatar
Liked: 30
Depending on the video card in it, you may want to upgrade to something with hardware MPEG2 decoding, as that will help lower CPU load.
Also, some motherboards that took a Pentium D can also drive a Core2 - if this can, that would be a good upgrade
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #6 of 8 Old 03-08-2012, 04:39 PM - Thread Starter
FHT123's Avatar
I guess ideally I do have not want to put any additional money in to it....plus I do not have the know how...
FHT123 is offline
post #7 of 8 Old 03-08-2012, 04:58 PM
Zon2020's Avatar
I have a 6 year old Dell Optiplex GX620 Small Form Factor Pentium D 2.8ghz with 3gb of DDR2. I put a $25 Radeon 5450 video card in it (Even you can do it, and it takes about 5 minutes). It depends on what you want to do with it, but it works fine for streaming and playing back video or playing DVDs.
I don't know what's required for the HD Homerun.
Put it this way. That Pentium D is a stronger processor than a brand new Atom or E-350.
I used a 512gb HIS Silence 5450, but any brand should be fine. Buy whatever 5450 card is cheapest. Sometimes they're under $20. You WILL want to put in a new video card.
I wouldn't sink a lot of money into it, but it is certainly worth a $25 upgrade.
Zon2020 is offline
post #8 of 8 Old 03-08-2012, 05:55 PM
erickotz's Avatar
Liked: 30
What video card is in it?
erickotz is offline
Reply Home Theater Computers
