Assuring 1080p at Powerup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-09-2012, 11:52 AM - Thread Starter
my-spot's Avatar
If my HTPC is powered on before the TV/AVR the HDMI output defaults to 480p (720x480) instead of 1080p. I don't recall having this problem in the past but then again I have just substainally updated my system.
HD 6570 (CC 12.1)-->(HDMI)-->Yamaha RX-V371-->(HDMI)-->P55VT30
Is there a (simple) way to lock in 1080p output?
(Or, is my only option to train my wife to turn the TV on first? )
Frank
my-spot is offline
post #2 of 6 Old 03-09-2012, 12:54 PM
Boke01's Avatar
I have the same setup as you but with a Vizio TV.
The Windows 8 consumer preview has fixed the 480p resolution problem for me.
I do still have the occasional loss of audio when resuming from sleep though. If I could figure that out it would be perfect.
Boke01 is offline
post #3 of 6 Old 03-09-2012, 01:02 PM
Sandy B Ridge's Avatar
I got around this problem by 'remoteing' into my HTPC with the receiver off and changing the display resolution to 1080p. I used splashtop remote from an iPad (set to 'use desktop resolution'). I'm not sure if VNC or other similar stuff will work too, but I haven't tried it.
The audio problem I got around by disabling all audio devices apart from HDMI. So it doesn't get stuck on anything else!
SBR
Sandy B Ridge is offline
post #4 of 6 Old 03-09-2012, 01:03 PM
Sammy2's Avatar
Quoted: 522 Post(s)
Liked: 254
Frank
Harmony Remote?
Sammy2 is offline
post #5 of 6 Old 03-09-2012, 02:15 PM - Thread Starter
my-spot's Avatar
SBR
Ahhh! Good idea - I see how that could do the trick. I use VNC on the system so I will give it a shot.
my-spot is offline
post #6 of 6 Old 03-09-2012, 09:36 PM
ericab's Avatar
if you are running openelec or xbmc, you can force an edid.
follow my instructions here:
http://openelec.tv/forum/67-display/...start=20#21288
ericab is offline
Reply Home Theater Computers
