Music options for Media Browser - AVS Forum | Home Theater Discussions And Reviews
Old 03-10-2012, 01:40 AM - Thread Starter
ataribravo's Avatar
Hi all,
I have been chomping at the bit to get music into WMC. I searched on "best music plugin for MediaBrowser" and MBMusic 2.0 keeps coming up, but I can find where to get it. It isn't on the list of plugins (at least I can't find it). I read the history of the plugin and it was sketchy. It was developed, then dropped and then picked up by someone else. Is it still available? What does the Music Support plugin do for you? Any recomendations?
Thanks!!
ataribravo is offline
Old 03-10-2012, 05:23 AM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
MB Music plugin: http://www.mediabrowser.tv/store/details/32
I haven't used it yet but I'll be getting it soon. A few people on here really liked it and no one had anything negative to say, so I guess that's a win.
Dropkick Murphy is offline
Old 03-10-2012, 12:04 PM - Thread Starter
ataribravo's Avatar
Thanks for the response! I bought the key (strange that it's the same key as CoverArt3), but I still can't find where to download/install the plugin. Help?
Old 03-10-2012, 01:05 PM
Quoted: 71 Post(s)
Liked: 89
It took me a while to figure that out myself. The key is the same whenever you buy a new item from the store as long as you used the same email address. Open up your media browser configurator and go to the Plug-in tab, then click on the new item and download.
Old 03-10-2012, 01:49 PM - Thread Starter
ataribravo's Avatar
Well, I open the Configurator and click on the Plug-ins tab, open the "Others" group and MBMusic isn't listed. That's why I'm confused.
I do have the latest MB (2.5.3) installed, however I did notice that if I go to download page on the MB site is says that 2.5.2 is the latest. Do I need to refresh somehow?
Thanks for your time...
Old 03-10-2012, 03:22 PM
Quoted: 71 Post(s)
Liked: 89
You have to click on "More Plug-ins" at the bottom and then look for music support. If this doesn't work for you I'm stumped. Get a hold of the support team.
Old 03-10-2012, 03:38 PM
Quoted: 71 Post(s)
Liked: 89
You could try this too.
http://community.mediabrowser.tv/per...-music-plug-in
You are using Win 7 right? The first paragraph says it won't work with XP
EDIT: Errr...Vista
Old 03-10-2012, 04:00 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I just installed it on another machine to test. Working just fine...
assassin is online now
Old 03-10-2012, 04:39 PM
jabberbox's Avatar
Awesome! Would love to be able to access music as well.
jabberbox is offline
Old 03-10-2012, 04:46 PM
FastM3's Avatar
Are there any other music options for MB or WMC?
FastM3 is offline
