PCM via Windows 7 set to stereo - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-11-2012, 01:42 PM - Thread Starter
Sammy2's Avatar
Quoted: 550 Post(s)
Liked: 262
I ripped Kill Bill Vol 1 &2 using MakeMKV. The audio is PCM 5.1 on both discs. have Window set to Stereo for appropriate playback of Live TV. When playing back KB I get only stereo, of course. I set Windows to 7.1 to get Multi-Channel playback.
Is there a way around this? It happened both in MPC-HC and MC.
Is there a program to create an mkv and convert the audio to TrueHD or dts-HD/MA?
Sammy2 is offline
post #2 of 3 Old 03-11-2012, 02:15 PM
captain_video's Avatar
Quoted: 524 Post(s)
Liked: 341
You can't convert the audio to either HD format if it's not on the original disc. Try using XBMC for mkv playback of ripped BD discs. There's a beta version available that bitstreams HD audio.
captain_video is offline
post #3 of 3 Old 03-11-2012, 03:09 PM
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 83
Yes, you can.
The truehd encoder is for mac, the dts-hd encoder is for windows.
They cost a lot of money though.
You can also use flac or wavpack for free lossless audio compression.
Flac probably shouldn't be used for more than 6 channels.
But these formats can't be bitstreamed over HDMI, so it doesn't really help you I suppose.
MlNDBOMB is offline
Reply Home Theater Computers
