FlexRaid alternative? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 03-13-2012, 03:28 PM
Smurf-IV's Avatar
On Windows - SnapRaid has a GUI called Elucidate
For Drive pooling there is Liquesce
Smurf-IV is offline
Old 03-13-2012, 04:19 PM
jim2100's Avatar
Liked: 34
Originally Posted by whiteboy714 View Post
Ha d alook at snapraid but it looks harder to set up than flexraid. Anyone know if the GUI can be used for setup? Seems like this needs to be done with command line.
snapraid can be set up with a simple text file, only 10 or 20 lines long (depending on how many drives you have and any exclusions). snapraid comes with example configuration files for windows and linux which you can just edit to customize for your system.
I have never used the GUI, since it is so easy and quick to setup with the simple text file configuration, but I guess you can set it up with the GUI. Why not try it both ways (text and GUI) and see which you prefer? It only takes a few minutes for the text file, and I guess the GUI does not take much longer.
jim2100 is offline
Old 03-13-2012, 04:44 PM
whiteboy714's Avatar
I was just a little worried about my data if I screwed something up. I know this is unlikely. I didn't know about the sample files. I actually haven't even downloaded it yet. Just looking up some info.
whiteboy714 is offline
Old 03-13-2012, 04:53 PM
jim2100's Avatar
Liked: 34
As long as you don't run the "snapraid fix" command, then snapraid will not change or delete any of your data. You can safely run "snapraid sync" or "snapraid check" with no risk. All it will do is read your data drives, and create parity and content files in the locations specified (but will not delete any files or folders already in those locations).
jim2100 is offline
Old 03-13-2012, 05:13 PM
Thanks. I'll give it a go.
Old 03-13-2012, 05:42 PM
Kind of confused at the difference between "content" and "disk" in the text file.
I: is my parity drive.
The drives I want to protect are F,G,H,J and L.
Any idea how to do this in the config?
Old 03-13-2012, 06:19 PM
jim2100's Avatar
Liked: 34
The parity file (keyword 'parity', and 'q-parity' for dual) contains the parity data that can be used for data reconstruction. The content file (key word 'content') contains checksums (aka, hashes) which can be used to verify the integrity of your data. If you have single parity, you must have at least 2 copies of the content file. But the content file is much smaller than the parity file. The parity files and content files are generated by snapraid ('snapraid sync'), and they must be specified as actual files in the configuration file (not just pathnames).
The data drives (keyword 'disk') are the locations of the data you want to generate parity and checksum data for. They specify pathnames to your data. But you can also store content files on the data disks (v1.8 of snapraid will automatically exclude the content files from generating parity data).
For a single parity drive, you probably want something like this (the excludes are copied from the example file, you may want something different there):
parity I:\\parity.par
content F:\\content.lst
content G:\\content.lst
disk d1 F:\\
disk d2 G:\\
disk d3 H:\\
disk d4 J:\\
disk d5 L:\\
exclude *.bak
exclude *.unrecoverable
exclude Thumbs.db
exclude \\$RECYCLE.BIN
exclude \\System Volume Information
block_size 256
jim2100 is offline
Old 03-13-2012, 06:22 PM
nexus99's Avatar
Pulled the trigger on a 4th 2GB drive. Will be building them into a 6TB raid 5 solution to hold photos/personal files/video/TV etc. Will be using the raid controller on the system board.
nexus99 is offline
Old 03-13-2012, 07:19 PM
disk d1 F:\\
disk d2 G:\\
disk d3 H:\\
disk d4 J:\\
disk d5 L:\\
exclude *.bak
exclude Thumbs.db
block_size 256
Thank you very much thats much clearer than the example. Sounds like I'm good to go. I was stuck on the content thing but that totally makes sense. Much appreciated!
Old 03-13-2012, 08:28 PM
Defcon's Avatar
Quoted: 1117 Post(s)
Liked: 578
I would like to use FlexRaid since it runs on Windows and the developer is very ambitious, he recently started a new project called NZFS which aims to recreate ZFS in some way, and FlexRaid has a lot of options and seems very full featured.
But these are also its cons. Its a 1 man project and I really have no idea when it will have a final release or be stable.
unRaid has very different goals - it just does 1 thing (even though there are plugins for things like torrents etc, its primarily just a file server), and development isn't nearly as hectic, but this means its more stable.
Defcon is offline
Old 03-13-2012, 09:00 PM
Thanks jim2100 I am syncing my drives now!
Old 03-13-2012, 09:08 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2687
hardware RAID > Software RAID
Simply better at everything.
That is all.
Mfusick is offline
Old 03-13-2012, 09:14 PM
That is all.
Not true. Its already been discussed in this thread.
Old 03-13-2012, 09:35 PM
Lars99's Avatar
That is all.
Certainly not true.
Lars99 is offline
Old 03-13-2012, 10:45 PM
cybrsage's Avatar
Liked: 154
Don't listen to Mfusick... He's lying!
cybrsage is offline
Old 03-14-2012, 07:17 AM
Darin's Avatar
It's better at some things, just not things that are important for a home media server.
You need to use the right tool for the job.
My dual Rythmik Servo sub project (actually quad now, need to update page)
HDM format neutral thanks to the pricing wars of the '07 xmas shopping season :)
Darin is offline
Old 03-14-2012, 08:14 AM
cybrsage's Avatar
Liked: 154
Be careful, you can lose all your data if your motherboard dies...
cybrsage is offline
Old 03-14-2012, 10:47 AM
JoshDorhyke's Avatar
False (implied) comparison.
It is easier to not set up drive pooling (compared to setting up drive pooling).
The choice is between the downside of setting up multiple volumes and the downside of setting up and running drive pooling. Either choice has downsides.
unRAID makes it very simple to set up a user share, which is the equivalent of drive pooling. You can also very easily use the server disk by disk for maintaining/uploading files and use the user share for viewing in your media players. Personally, I think it would be dumb to point XBMC to multiple network shares for each disk compared to just pointing it to a user share.
JoshDorhyke is offline
Old 03-14-2012, 11:10 AM
jim2100's Avatar
Liked: 34
unRAID takes a LONG time to set up if you already have HDDs with data on them. You have to copy all your data over to unRAID at speeds slower than the write speed of your HDDs, which is a major pain. A huge waste of time.
SnapRAID is much less restrictive.
jim2100 is offline
Old 03-14-2012, 12:54 PM
What does that have to do with the usefulness of the user share or drive pooling function?
The problem you're complaining about is one of migrating to unRAID from another system. Similar issues can occur when moving to or from a RAID5 or RAID6 array or from or to say a Drobo.
Old 03-14-2012, 02:51 PM
jim2100's Avatar
Liked: 34
Well, in your own words, it is "dumb" to spend a few minutes entering into XBMC the pathnames of the volumes where you have stored your media files.
So, what word would you use to describe spending hours or days copying media files from your existing collection onto an unRAID server?
jim2100 is offline
Old 03-14-2012, 03:05 PM
video321's Avatar
Quoted: 21 Post(s)
Let's make this simple, jim2100-
Not all players, whether hardware or software-based, can "pool" multiple paths. I have a couple WDTV Live players which can't and that means hitting multiple paths to find the movie you're looking for - not exactly WAF. As I mentioned above, I use junctions to get around that limitation so every movie is listed under a single "Movies" share.
video321 is offline
Old 03-14-2012, 03:16 PM
jim2100's Avatar
Liked: 34
In which case it makes sense to use some sort of merging or pooling. But pooling is available with any of the systems (SR, FR, UR), so it is not a big factor in deciding between them.
jim2100 is offline
Old 03-14-2012, 03:29 PM
Defcon's Avatar
Liked: 578
All the HTPC frontend's (XBMC, MP, MB) support multiple media sources so pooling is not needed. I don't know about standalone players. We should distinguish between true drive pooling and simply merging contents of different folders.
1. Drive pooling is when multiple drives/sources appear as a single source, and you can read/write to it without worrying about the physical location, and the files are balanced across drives as needed.
2. And then you have something like Libraries in Windows 7, junctions/symlinks, multiple paths in a XBMC source etc. All these will let you see all the content as 1 folder, but it doesn't actually manage the data for you or handle drives getting full.
For most people #2 is more than enough I think.
Defcon is offline
Old 03-14-2012, 03:32 PM
Defcon's Avatar
Liked: 578
That is all.
HW Raid is a recipe for disaster in a home environment IMO. Raid doesn't provide backup, all it gives is the illusion of safety. Using expensive HW Raid just to get drive pooling seems like massive overkill.
Defcon is offline
jim2100's Avatar
Liked: 34
Good point.
jim2100 is offline
Old 03-14-2012, 10:00 PM
cybrsage's Avatar
Liked: 154
The OP said he is looking to migrate from another system...so it is very useful info.
Unraid being linux is the main reason I passed it by way back when I first heard of it. If I decided to stop using it, I would have to migrate my data back to Windows in order to have access to it again.
cybrsage is offline
Old 03-14-2012, 10:02 PM
cybrsage's Avatar
Liked: 154
I only need to protect movies, so I manually put the movie folder (containing actual folder content or an ISO) where I want it to go, so I have 100% control over its location. I then put a shortcut to the folder on one drive in a folder named "Movies". I point everything to the movies folder and it appears as it all the movies are actually there.
Since I am only ever ripping one movie at a time, and only now and again when I buy a new one, the 3 or 5 seconds it takes to create the shortcut is meaningless.
cybrsage is offline
Old 03-15-2012, 04:42 AM
sneals2000's Avatar
Quoted: 253 Post(s)
Liked: 131
Or you could install suitable drivers on your Windows PC and read (and I believe write) the contents without migration.
And the comments about migration to unRAID at being at less than disk write speeds is less of an issue if you use a cache drive (which unRAID supports) and then let unRAID copy the material across in the background.
I migrated 5TB of NTFS drives from a Windows set-up to unRAID about 2 years ago and have never looked back. I now have 14TB of media stored on my unRAID set-up and I'm very happy with it.
User Shares are a huge benefit if you use hardware players like WDTV Live, Popcorn Hour etc., as being able to point to a single 'Movies' or 'Recorded TV' mount point makes things a lot simpler.
YMMV - but I am very glad that I went with unRAID. Two years of it 'just working' has been great for me.
sneals2000 is online now
Old 03-15-2012, 05:36 AM
captain_video's Avatar
Quoted: 512 Post(s)
Liked: 338
And that's what really counts in the end, isn't it?
captain_video is online now
