Netflix plugin for WMC to the new format? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-12-2012, 12:56 PM - Thread Starter
ajiva's Avatar
Does anyone know if the WMC Netflix plugin will ever get updated to match the PS3/XBox/Roku versions? The WMC plugin makes me scroll through the episodes rather than sorting by seasons.
ajiva is offline
post #2 of 5 Old 03-12-2012, 04:52 PM
freetvEE's Avatar
Quoted: 24 Post(s)
That would be nice, but they don't seem too concerned about the current netflix WMC app from what I have seen. It also has issues where it will freeze up at then end of a show if you let it go all the way to the end (ongoing for 6 months), and that hasn't been fixed either...
freetvEE is offline
post #3 of 5 Old 05-05-2012, 09:03 AM
mlm39's Avatar
I've been playing with Netflix on my 3 PCs for the last 2 weeks, under WMC and Internet Explorer. I have an early Atom netbook, an E-350 HTPC and an Athlon II X4 645 desktop. We all know about the problems with Netflix/Silverlight so I won't go into that other than to say that I have achieved smooth playback at bit rates of 1050 on the Atom, 1750 on the E-350 and 3600 on the Athlon.
One thing I have noticed that I can't find mentioned on the internet is that regardless of the PC I am using, A/V Stats shows on the //HTTP line that when running Netflix under IE, Silverlight 5 is referenced:
(http://movies.netflix.com/layout/sil...2.1358.314.2-2)
while when running under WMC, Silverlight 4 appears
(http://www2.netflix.com/pages/watchn....xap?v=1315207).
I can only assume this proves that the WMC Netflix add-on has not yet been updated to utilize the capabilities of Silverlight 5.
Has anyone else noticed this?
mlm39 is offline
post #4 of 5 Old 05-05-2012, 10:00 AM
lockdown571's Avatar
Quoted: 36 Post(s)
Liked: 87
The chance of the WMC plug-in getting updated is slim to none. Our best hope is that Netflix releases a Windows 8 metro app for x86 systems.
lockdown571 is offline
post #5 of 5 Old 05-07-2012, 02:55 PM
freetvEE's Avatar
Quoted: 24 Post(s)
You might add this info to this long thread to see if it helps anyone troubleshoot the issue: http://experts.windows.com/frms/wind...72.aspx#552472
freetvEE is offline
Reply Home Theater Computers
