Best keyboard wth a built in mouse - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 32 Old 03-29-2012, 11:47 AM
scoyne88's Avatar
I like using a larger keyboard for times when I need to search the internet for software, updates etc. I like the IOGear multimedia remote, and a Harmony 300. For the range of the IOgear keyboard, I took the casing off the USB dongle, stripped the coat off one strand of a cat-5 cable, twisted the bare cable to a stripped portion of a RP-SMA cable and then plugged the cable into a WIFI antenna. I can use my keyboard in the next room with the HTPC inside a cabinet.
Before you criticize someone, you should walk a mile in their shoes.That way, when you criticize them, you're a mile away and you have their shoes.
DIY Speaker Cables
http://www.seancoyne.org
scoyne88 is offline
post #32 of 32 Old 03-29-2012, 04:57 PM
dcard's Avatar
Quoted: 27 Post(s)
Originally Posted by assassin View Post
Wow. That thing is huge.
twss
dcard is offline
Reply Home Theater Computers
