is picture in/and picture possible using ceton? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-25-2012, 10:31 PM - Thread Starter
Ou8thisSN's Avatar
Quoted: 191 Post(s)
Liked: 27
I want to get an HTPC (just a dell desktop, too lazy to build a computer) and run either the ceton card or HD Homerun.
I was wondering do any of these cards/programs support picture and picture? like ESPN3? ideally it would be cool to have something like that in time for football season
Ou8thisSN is online now
post #2 of 7 Old 03-26-2012, 05:26 AM
captain_video's Avatar
Quoted: 511 Post(s)
Liked: 336
PiP is a feature supported by your display, not your PC. You need two separate inputs to your TV to support PiP. Graphics cards only support a single output (or multiple outputs of the same signal) so you'll need another source for the 2nd input to your TV if you want PiP.
captain_video is offline
post #3 of 7 Old 03-26-2012, 09:05 AM
spivonious's Avatar
That's not entirely true. If you could find software for the PC that supported PiP, it could use two of the tuners in the Ceton to do it. I've never come across any though.
spivonious is offline
post #4 of 7 Old 03-26-2012, 11:59 AM
Quoted: 511 Post(s)
Liked: 336
In other words, if pigs could fly....
post #5 of 7 Old 03-26-2012, 11:59 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Absolutely, as long as your TV supports it.
Use Input 1 from HTPC, and use Input 2 from a media center extender.
Tune HTPC to a Channel, and tune the media center extender to another channel.
I did something similar for a customer, who wanted a large screen TV, and 4 smaller screens on top, so that he can view a game on large TV, and 4 other games on smaller TV's.
It works like a charm.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #6 of 7 Old 03-26-2012, 12:04 PM
Quoted: 511 Post(s)
Liked: 336
And that's exactly what I was saying previously. Your TV needs two separate inputs to have PiP. Blueiedgod's approach is a simple workaround that will do exactly what the OP is asking for using the InfiniTV 4 as a sole source. The one caveat is that you need to make sure your extender's remote doesn't interfere with the Media Center controls if you have them in the same room. I believe the Linksys extenders will react to a WMC remote if placed near each other. OTOH, the XBox remote and the HP x280n extender remotes don't interfere with WMC, IIRC.
post #7 of 7 Old 03-26-2012, 12:18 PM - Thread Starter
Ou8thisSN's Avatar
Quoted: 191 Post(s)
Liked: 27
my display has "picture and picture" but I was hoping that the software could do it, like ESPN3 does.
I suppose during football season i'll bring down a second extender and do it that way. Still annoying though.
Reply Home Theater Computers
