will 3/4" of wood obstruck inserting DVDs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 03-28-2012, 02:05 AM - Thread Starter
stevethebrain's Avatar
Quoted: 105 Post(s)
Liked: 25
I'm concidering conceiling a tower PC inside my home entertainment center and cut a hole for the DVD tray then cover cuts w/ a DVD cover.
will 3/4" of wood obstruck inserting DVDs?
Thanks STB
By stevethebrain at 2012-03-28
edit initial plan was to lay the tower PC on it's side and have it adjacent to the AVR however I have been adviced that a tower is designed to be vertical and placing it horizontal would put extra wear on the HDD becauce tower HDD are designed to be horizontal, this confusses me because XBoxs have vertically mounted HDD.
option2 for horizontal tower, I'm now thinking obtain a Xbox HDD and use the towers HDD as an external HDD.
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #2 of 16 Old 03-28-2012, 08:51 AM
Zon2020's Avatar
If someone here agrees with that or provides any evidence to support that view I'll be surprised -- no, make that stunned -- because I'm pretty certain that it is utter nonsense. There's no such thing as a "tower HDD." They're all the same and they will work perfectly fine in either a vertical or horizontal orientation. While I wouldn't advise it, they'll even work fine upside down. The heads do not rely on gravity to maintain spacing with the platters.
The optical drive will also work fine in either orientation.
Zon2020 is offline
post #3 of 16 Old 03-28-2012, 08:56 AM
walford's Avatar
Years ago CD disk drives were designed to be horizontal mounted upright but I have not seen with that restriction for at least 10 years. if not 20.
You also need to insure that you have adequate ventilation in the cabinet to remove the heat generated by the system and it's drives.
You also need to insure that you have access to the open button and the manual force open "hole" on the front of the drive.
The reason for the required mounting position was that the early drives did have a good reliable way to insure that the disk media stays in position properly in the tray.
walford is offline
post #4 of 16 Old 03-28-2012, 09:07 AM
bjterry62's Avatar
Don't worry about the HDD. Whoever told you that it needs to be oriented in a certain way is full of crap. Getting to your original question about the DVD drive, as long as your opening (in the cabinet) does not contact your drive tray, you should have no problems.
BT
Just remember, to the MPAA "We're all guilty until..............."
bjterry62 is offline
post #5 of 16 Old 03-28-2012, 09:12 AM
cdru's Avatar
Quoted: 20 Post(s)
What's wrong with advising it? I've velcroed many drives to cases upside down to avoid sticking it to the circuit board. Never a problem.
cdru is offline
post #6 of 16 Old 03-28-2012, 09:36 AM
Zon2020's Avatar
Well, I couldn't think of a good reason to do it, but you provided one. I was thinking of why would one choose to install the drive upside down in a normal mount. (Although actually many many years ago when I simply didn't know which way they were supposed to go I installed one upside down and used it for years that way without a problem without knowing it was upside down.) If the best way to mount it in a particular situation was upside down, I'd certainly do it that way.
Zon2020 is offline
post #7 of 16 Old 03-28-2012, 09:43 AM
hirent's Avatar
I call BS!
I have seen numerous Dell Desktops which had vertically mounted hard drives (Dell Dimension 2400 series).
I have had some systems where the hard drives have been hanging on the floor of the case, simply supported by the power and data cables. While I wouldn't suggest it for every situation, they have been running fine for years.
I would suggest you to go ahead and lay it down and not bother about cutting anything out.
hirent is offline
post #8 of 16 Old 03-28-2012, 10:13 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
You can get a slot fed DVD drive, that way you don't have to cut a hole for the whole tray. Pioneer makes them. They are not $15 that you paid for the Asus, but it won't look like crap just having a slit for the DVD's on the side.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #9 of 16 Old 03-28-2012, 11:58 PM
tomandbeth's Avatar
A good woodworker would use either matching vaneer or a slice of the cutout and put it on the DVD door. Depending on how good the woodworker is, it would never show. The button to operate it could be made to look like a small knot.
tomandbeth is offline
post #10 of 16 Old 03-29-2012, 05:37 AM - Thread Starter
Quoted: 105 Post(s)
Liked: 25
I now believe the advice I recieved on the tower HDD must being horizontal prior to this thread was bogus, come to think of it my Western digital world book external HDD is also vertical.
I am now curious where this case draws cooling air in from, I observe no holes on the front of this case however I do observe a mesh like piece on the inside front bottom (where usalley a air fliter would be).
other observations on venting air out is a tube ontop of the CPU, PSU fan
aparently there is a spot for a third fan on the center of back case I don't believe its included.
Thanks Guys for the advice
link to PC
http://www.newegg.com/Product/Produc...=11zngc5ok4ah7
post #11 of 16 Old 03-29-2012, 05:46 AM
bryansj's Avatar
Quoted: 1136 Post(s)
Liked: 560
link to PC
Usually with a case like what you've linked there will be an opening at the very bottom front edge. You would need to ensure you have some space between the front and the cabinet. However, if you can lay it on the side and maintain proper ventilation then go that route. It'll keep you from having to cut out a slot in the cabinet that may or may not even work.
Another thing, I don't even remember the last time I even opened the DVD drive on my HTPC. I do all my ripping on a laptop and transfer the files from there.
bryansj is online now
post #12 of 16 Old 03-29-2012, 06:46 AM - Thread Starter
Quoted: 105 Post(s)
Liked: 25
Hello Bryan yes laying it on it's side would be more advantagous to me, like acessing the SD card reader slot, top USB plugs on/off buttom (incase I need to physicalley power down) ect.
I was planning on using the behind TV cabient space for HDD media storage area.
I haven't had a chance to observe this case in person yet.
?1.do you think the lower inside bottom mesh section contains a air fliter.
?2.I'm assumming this PC only comes w/ a CPU fan and a PSU fan and this case is also used for PCs (hence the extra fan spot) w/ extra modules like TV tuners graphics ect.
I only plan a TV tuner, what do you think about a third fan?
?3.how is inside PC temp. determined, like can I find this in control panel? or is there like a air temp guage?
Thanks STB
post #13 of 16 Old 03-29-2012, 08:11 AM
bjterry62's Avatar
I'm pretty sure that cabinet is veneer (possibly vinyl) Trying to make it look natural would be folly. Disassembling the entire entertainment center to cut it on a scroll saw (necessary to make the cutout fit neatly) would also be a huge job for little benefit.
post #14 of 16 Old 03-29-2012, 08:28 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Another option is to get a USB or eSATA drive, and place it where it is easier to access.
post #15 of 16 Old 03-29-2012, 09:06 AM
Zon2020's Avatar
This is the best solution yet.
Not only where it is easier to access, but it can be totally hidden and out of the way except for the infrequent times when it's actually being used.
Zon2020 is offline
post #16 of 16 Old 03-29-2012, 10:13 AM
bryansj's Avatar
Liked: 560
The best solution would be to just lay it horizontally and not have to cut a hole or buy an external unit.
Reply Home Theater Computers
