Advice on a SAS Expansion Card for My Build. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-28-2012, 09:41 AM - Thread Starter
Griff1324's Avatar
Quoted: 12 Post(s)
Liked: 27
I am upgrading my media server. I am moving away from my hardware RAID 5 setup and going to FlexRaid. I just purchased a Norco 4224 case to replace my old case. Since the backplane in the case uses SFF-8087 connectors, I am looking for some affordable cards with SFF-8087 connectors on them.
Any recommendations?
Griff1324 is offline
post #2 of 6 Old 03-28-2012, 10:13 AM
Mark Guebert's Avatar
Quoted: 36 Post(s)
Liked: 32
I am using two rocketraid 2680 pcie cards, in a Norco 4220 box with 4 sas cables to the backplanes on W7x64 and Flexraid snapshot raid with pooling. I currently have about 13tb in the box with plenty of room for expansion. It has worked well for me and the cards are available on Newegg for $99
Mark Guebert is online now
post #3 of 6 Old 03-28-2012, 10:36 AM
Lars99's Avatar
I would recommend two of these.
You would also need forward breatkout cables. Also make sure your MB supports 2x at least x4 PCI-e slots.
Lars99 is offline
post #4 of 6 Old 03-28-2012, 11:29 AM - Thread Starter
Griff1324's Avatar
Quoted: 12 Post(s)
Liked: 27
Correct me if I am wrong but I will not need the breakout cables since the Norco 4224 uses an SFF-8087 connector on the backplane. I would also need three of these cards (if I wanted to max out the HDs) since I have 6 backplanes in the Norco 4224, correct? Each port on the card going to each backplane in the case.
post #5 of 6 Old 03-28-2012, 11:40 AM
Acesfullup's Avatar
Originally Posted by lars99 View Post
i would recommend two of these.
+1
Acesfullup is offline
post #6 of 6 Old 03-28-2012, 11:46 AM
Lars99's Avatar
You still have SATA ports on the MB.
Probably easier to explain with pictures. Here's a guy who did an unRaid build using that case and a complete parts/pictures list. Hope this helps.
http://lime-technology.com/forum/ind...?topic=12822.0
Lars99 is offline
Reply Home Theater Computers
