**To all media storage server owners...power consumption** - AVS Forum | Home Theater Discussions And Reviews
post #1 of 61 Old 04-02-2012, 11:48 AM - Thread Starter
N3W813's Avatar
Quoted: 22 Post(s)
Liked: 70
I would like to poll all media storage server owners to post their server's power consumption when idle. Currently, my server is using ~280W idling costing me about $70-75 per month in electricity usage. I would like to build a new server as a replacement that uses lower power consumption.
CASE: Dell Poweredge 2900 III
POWER SUPPLY: 930W
CPU: 2x Intel Xeon 5405
MEMORY: 8x 2GB FB-DDR2 ECC
CONTROLLER: PERC 6/i
HARD DRIVES: 3x 300GB SAS, 7x 2TB Hitachi 7K2000
ADD-ON1: Ceton InfiniTV CableCard Tuner
ADD-ON2: 2x eSATA port PCIe adapter
OS: Windows Server 2008 R2
POWER USAGE: ~380W (idle)
My ArgyllCMS/MadVR 3DLUT Creation Workflow
My Sharp Elite Movie THX AV Mode Settings
--Aug 2011 Set, 2.2 gamma [ link ]
--Nov 2012 Set, 2.2 gamma [ link ]
N3W813 is offline
post #2 of 61 Old 04-02-2012, 12:28 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
CASE: Lian-Li PC-Q07B
POWER SUPPLY: FSP Group FSP300-60GHS(85) 300W SFX12V 80+ BRONZE
CPU: AMD E-350 APU (ASUS E35M1-I)
MEMORY: 1 x 4GB Kingston DDR3 non-ECC
CONTROLLER: on-board (Realtek)
HARD DRIVES: 1 x Kingston V100 64GB SSD, 2 x 2TB Samsung HD204UI, 1 x 2TB Seagate, 1 x 1.5TB WD Green, 1 x 1TB Seagate
USB: UPS battery monitor
FANS: 1 x 140mm, 1 x 120mm
OS: WHS2011
POWER USAGE: ~30W (idle) (IIRC - will re-measure again with Kill-a-Watt)
StardogChampion is offline
post #3 of 61 Old 04-02-2012, 03:46 PM
user4avsforum's Avatar
HP Media Smart x310
Upgraded to WHS 2011
Atom D510
2GB RAM
2x 2TB HDD
2x 3TB HDD
~20-30w (idle->load) IIRC. I will check again.
user4avsforum is offline
post #4 of 61 Old 04-02-2012, 04:13 PM
paulinmn's Avatar
I have an inkling that your PSW might be the culprit. Maybe a bit overkill. You don't list the make or model. What energy certification is it? It might be more cost efficient to replace that if it is the issue than to entirely rebuild your server.
paulinmn is offline
post #5 of 61 Old 04-02-2012, 04:17 PM
hirent's Avatar
E6850 (65W max TDP)
PSU: Azza Dynamo 850W (70% efficiency)
Hard Drives: 9 (Green Drive)
Video Card: Silent HD5450
3 add-on cards
1 optical drive
Idle Power (measured with Kill-A-Watt): ~150W
hirent is offline
post #6 of 61 Old 04-02-2012, 04:30 PM - Thread Starter
N3W813's Avatar
Quoted: 22 Post(s)
Liked: 70
It's a Dell server...so it is a proprietary Dell power supply. I've looked for lower consumption replacements but no other manufacture makes it.
N3W813 is offline
post #7 of 61 Old 04-02-2012, 05:10 PM
kegobeer's Avatar
H55M Pro w/Core i3-530
Unknown 250W power supply (came with a rescued 4U server case)
Highpoint RAID card + 4 1TB WD Green drives for data
1 640GB WD Caviar Black (running WHS 2011)
24 port D-Link 24 port "Green" switch
Motorola SB6120 cable modem
HDHomeRun Dual
All connected to the same UPS for a total of 64 watts.
kegobeer is offline
post #8 of 61 Old 04-02-2012, 06:13 PM
xfett's Avatar
Freenas 8.2 BETA
ASROCK E350M1 {CPU fan lvl 1 in BIOS}
Pareema 4GB (2 x 2GB)
Intel EXPI9301CTBLK NIC
4 - WD20EARS 2TB HDD
1 - Barracuda 2TB HDD
picoPSU-150-XT PowerSupply
Raidmax ITX case
1 - Noctua NF-R8-1800 {lvl 1 manual speed control in BIOS}
16 W idle (HDD spindown) ~ 24 - 28 W max load
"Man, I told you we shouldn't have shot Niedermeyer"
xfett is offline
post #9 of 61 Old 04-02-2012, 06:49 PM
gregzoll's Avatar
Liked: 33
Yes, running a computer 24x7 can cost money. The only thing you can do, is utilize WOL, or start using stand-by settings, that it will wake up when it senses the HDMI port asking for a signal, then have it shut down after 30 min's or such, when it no longer senses the signal on the hdmi port.
There is no way around it, unless you start looking at habits and figuring how to change them to save money. Our household on average uses at the most 600kwh a month, and it costs us at the most about $75 for electric. Our average bill has been with Sewer, water, electric $106. I do not really worry about it, due to technology has become a everyday habit with most households.
I use a Ted5000 to keep track of what is using what, and can pretty much nail the bill down to the use per month for our household. In the middle of the night, it is funny to see our house only using one cent a hour, the most four cents per hour in the middle of the night.
gregzoll is offline
post #10 of 61 Old 04-02-2012, 07:07 PM
Somewhatlost's Avatar
Quoted: 20 Post(s)
Liked: 25
case NORCO 16 bay
cpu/MB little Supermicro Atom board
6 HDD various sizes/brands
running unRAID
watt = ~20 idle
NOTE: As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists. so don't take anything I say as advice...
Somewhatlost is offline
post #11 of 61 Old 04-02-2012, 07:21 PM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
Case: Antec 300
PSU: Corsair HX520
MB: ABIT AB9 Pro
CPU: Intel Celeron 430
RAM: Kingston 2x2GB DDR2 800
HDD: 9x Seagate Barracuda 7200.11 1.5TB
OS: unRAID
Code:
Boot                    264.0W
Idle (Spun-Up)          145.0W
Idle (7)                127.0W
Idle (5)                113.0W
Idle (3)                 99.5W
Idle (2)                 92.0W
Idle (1)                 84.5W
Idle (Spun-Down)         77.0W
Parity Check            169.0W
ilovejedd is offline
post #12 of 61 Old 04-02-2012, 11:07 PM
dj4monie's Avatar
Quoted: 37 Post(s)
Liked: 25
Wow, why would you put a business/enterprise class server in your house?
Unless your transcoding or encoding for speed, then I can see why some use dual core desktop CPU's.
However serving files does not take much power. Once the madness dies down around Raspberry Pi and are readily available, I believe you can put FreeNAS on that and use a powered USB hub to put a few external drives on it.
That would be a seriously low powered server (9W maybe?), likely under 20W with drives connected.
A Zacate or Atom board is plenty for a home server, especially for WHS 2011.
I use a Dell Mid Tower P4 Prescott based PC. Not sure what it uses but reports show at idle P4's are around 65W and 90-100W at load, but its hardly ever under load. I don't have a Kill-A-Watt yet, being cheap I haven't purchased one yet. Limited income too...
A. Thomas
PSN - DJFourMoney
dj4monie is offline
post #13 of 61 Old 04-03-2012, 07:40 AM
packetlosss's Avatar
I had been using a P4 as my fileserver, but after I checked it's usage (around 70W idle and 110W under load), I replaced it with a G530 that idles at 30W.
packetlosss is offline
post #14 of 61 Old 04-03-2012, 11:01 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Pentium II 6 TB RAID 5 server, 60 watt full load, 30 watt idle.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #15 of 61 Old 04-03-2012, 11:13 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 242
I have a SNB Celeron in mine. I have to get my Kill-A-Watt back and will test it out. I would think its much less than 100 watts though with 4 green hard drives and a 400W PSU.
assassin is offline
post #16 of 61 Old 04-03-2012, 11:20 AM
cdru's Avatar
Quoted: 20 Post(s)
How did you compute $70-75?
280 watts * 24 hours * 30 days = 201.6 kWh. Highest average electricity cost in the nation is Hawaii at ~$.25/kWh. That would only be ~$50/month.
cdru is offline
post #17 of 61 Old 04-03-2012, 12:19 PM - Thread Starter
N3W813's Avatar
Quoted: 22 Post(s)
Liked: 70
It was a refurbished unit from Dell Outlet, I got it REALLY cheap. I do run 5 VMs on Hyper-V on the box running AD, DNS, and other infrastructure services. I work in IT so I use my home as a test lab so to speak.
Sorry the wattage I typed in the first post is wrong, it's 380W. :P And my tiered rate is at 0.28 per kwh.
I've since pulled out the 2nd CPU and removed 8GB of memory dropping the power consumption to about 300W.
I would love to go with Unraid with hard drive spin down but I absolutely need to run Windows so I can run VMs.
N3W813 is offline
post #18 of 61 Old 04-03-2012, 02:58 PM
Glimmie's Avatar
Quoted: 732 Post(s)
Liked: 592
Why do we need to run 24/7? I only power up when needed.
Glimmie is offline
post #19 of 61 Old 04-03-2012, 04:17 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
How do you power up?
Also, how would you power up if you're not home and some someone wants to watch a movie or listen to music?
Mrkazador is online now
post #20 of 61 Old 04-03-2012, 09:03 PM
brianley's Avatar
WOL (Wake On LAN) / magic packet I expect.
brianley is offline
post #21 of 61 Old 04-04-2012, 10:48 AM
whiteboy714's Avatar
Whoa the OP is drawing some serious juice. I run an athlon quad (actually an unlocked tri) with like 7 hard drives. Don't have a kill a watt though. Hoping its under 100 watts.
whiteboy714 is offline
post #22 of 61 Old 04-04-2012, 10:58 AM
Quoted: 20 Post(s)
Liked: 25
so every time he wants to use any networking (DNS/Active Directory/etc server), you needs to send a magic packet, and wait for not just the server to come up, but also wait for all the VM's to come up?
I would just rather get a more power efficient server and leave it on 24/7... but hey, that's just me...
post #23 of 61 Old 04-04-2012, 11:00 AM
FantaXP7's Avatar
Quoted: 44 Post(s)
Liked: 38
I'm getting curious now myself...
I have a Core2Quad 6600 and 8 hard drives.
I would immediately downgrade to some atom system, but I have virtual machines running so I need Intel VT-D.
If I find that my cpu usage is very high in my server I would consider buying a newer sandybridge i3...
Guess I won't know until I use a kill-a-watt.
FantaXP7 is offline
post #24 of 61 Old 04-04-2012, 11:43 AM
cdru's Avatar
Quoted: 20 Post(s)
Your processor TDP is 65 watts, and the average 3.5" hard drive is around 5 watts idle. It's a pretty safe presumption that you're over 100 watts.
cdru is offline
post #25 of 61 Old 04-04-2012, 12:21 PM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Depending on which athlon you have, some are 125 watt and some are 65 or 95 watt.
but, you are probably over 100.
I had a dual core Atom N330 for HTPC and it peaked at 30 watts, and idled at 5 watts. That was with 2x ATI DCT's.
post #26 of 61 Old 04-04-2012, 01:01 PM
Yah I guess your right. Don't think it would be worth it for me right now to do an upgrade.
post #27 of 61 Old 04-04-2012, 01:51 PM
-Axle-'s Avatar
Quoted: 35 Post(s)
Liked: 31
It all depends on how intensive your server needs are. I just use mine as a server backup and media streaming (video and audio).
I'm batting about 30W idle and 50W-60W or so under load.
CASE: InWin somethingorother
POWER SUPPLY: 300W
CPU: Intel E3300
MEMORY: 2GB DDR2 800
CONTROLLER: N/A
HARD DRIVES: 1x WD 2TB 7200RPM SATA
OS: Windows 7 32-bit
__________________________________________
My Living Room HT
-Axle- is offline
post #28 of 61 Old 04-04-2012, 01:55 PM
-Axle-'s Avatar
Quoted: 35 Post(s)
Liked: 31
If I could have gotten it to work, I would've done it the same way.
I tried initially setting my server to suspend to S3 state, but it would take quite a while for it to come out of suspend AND respond to network demands. So I just left it on 24/7, but if the other guy go it to work for his needs, good for him.
My Living Room HT
-Axle- is offline
post #29 of 61 Old 04-04-2012, 01:59 PM
maxpower47's Avatar
TDP is a specification of the maximum cooling capacity needed for the processor. Your idle power usage by the cpu is much lower than that. Under media server type workloads, the average power usage by the cpu should be very close to the idle usage.
maxpower47 is offline
post #30 of 61 Old 04-04-2012, 02:29 PM
Yah that part didn't make sense to me. But I think the fact that mine is unlocked will raise the power a bit. But I keep cool and quiet on. Just checked and it was sitting at 800mhz.
Reply Home Theater Computers
