couple ?s on antennas - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-06-2012, 02:26 AM - Thread Starter
stevethebrain's Avatar
Quoted: 105 Post(s)
Liked: 25
I'm concidering this for a HTPC. couple ?s on antennas
http://www.ascendtech.us/acer-am3910...?agent=froogle
?1.doe's this wireless card require an antenna? or should the PC be tested w/out antenna first
before buying an antenna?
can this TV tuners antenna be used as a wireless antenna?
http://www.newegg.com/Product/Produc...82E16815116034
also is this a decent wireless antenna?
http://www.newegg.com/Product/Produc...-pla-_-NA-_-NA
and this for a TV tuner
http://www.newegg.com/Product/Produc...82E16815116036
?2.I'm assumming this tuner that costs $10. more includes the software for it to work correctly?
unlike the one that cost $10. less that requires third party software for it to work correctly?
?3.will a 3' piece of coax wire make a good FM antenna?
?4.doe's the WMC remote have a button to record FM to HDD?
Thanks STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #2 of 5 Old 04-06-2012, 08:27 AM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
The link is for an external Hauppage usb tv tuner which is used to watch OTA tv channels. In order to pick up as many stations as possible, it would be best to connect the Hauppage to an outdoor antenna such as one made by Channel Master or Antennas Direct. You could test the tuner in your htpc by using the included indoor antenna, although you may not pick up any stations, depending on where you are located.
This Hauppage cannot be used to anything related to networking or the Internet.
This antenna is for use with a wireless network device. I would only get the antenna if you are having signal problems when connecting the htpc to your wireless network. In order to use this antenna, your external or internal wireless device must allow you to connect an external antenna.
This is also a tv tuner and provides some features in addition to the features of the Hauppage you linked in your first question.
I would not bother using the included tuner software. Just use Windows Media Centre to handle watching, recording, and playback of recorded tv.
Maybe, maybe not. You may be better off using a plain di-pole antenna.
I'm not sure but you would probably get better sound quality when recording from some high-quality Internet radio stations.
audit13 is offline
post #3 of 5 Old 04-06-2012, 09:52 AM
djearl81's Avatar
Quoted: 12 Post(s)
Hi STB,
I can't speak for the pc tuner cards, but these two sites were very helpful to me when choosing an antenna for our set top boxes.
Find which size antenna you need:
http://www.antennaweb.org/
I find this site to sell the best antennas. (Obviously it's a personal preference.):
http://www.antennasdirect.com/
I had an early version of the DB2 antenna in my attic for about 5 years and didn't have any problems with dropped signals even in bad weather. We've used the picture frame antenna in a few family homes with mixed results.
I'm confused too.
djearl81 is offline
post #4 of 5 Old 04-07-2012, 06:33 AM - Thread Starter
Quoted: 105 Post(s)
Liked: 25
actualley I was kindof asking about the PCs wireless card needed a antenna, and maybe use a small TV tuner antenna (that I allready have) maybe wireless technology uses differnt frequencys?
secondly I was kindof asking about the TV tuners card FM section using a simiairl 3' piece of coax that I use on my AVR as an FM antenna.
Thanks STB
post #5 of 5 Old 04-07-2012, 09:32 AM
whiteboy714's Avatar
Yes a wifi card needs an antenna but it should come with it. Unless you got it second hand or something.
whiteboy714 is offline
Reply Home Theater Computers
