Cheapest ever HTPC that's decent. Proud of myself. - Page 35 - AVS Forum
Old 07-30-2014, 01:55 PM
Dark_Slayer's Avatar
Quoted: 278 Post(s)
Liked: 327
Originally Posted by renethx View Post
Bay Trail-M and D (Celeron N2820, J1800, J1900 etc.) is also reported to support 3D
Have you had a chance to test the j1800 or j1900 to date renethx?
Dark_Slayer is online now
Old 07-30-2014, 02:26 PM
AVS Club Gold
renethx's Avatar
Quoted: 241 Post(s)
Liked: 390
Not yet. Only one person reported that Bay Trail supports 3D. But he didn't say which 3D format he meant. Ark.Intel says Bay Trail does not support 3D. I will test J1900 soon anyway.
Instead I tested AMD Athlon 5350 (AM1 platform). It supports 3D (MVC decoding and Frame Packing output) and HD audio bitstreaming. This is the cheapest 3D solution. I am getting Sempron to see if it supports them too.
renethx is offline
Old 07-30-2014, 06:01 PM
Quoted: 278 Post(s)
Liked: 327
Good to know, I look forward to your results
Just spouting an idea, but they were probably playing back hSBS in XBMC Gotham -- no hardware acceleration as I'm aware, but I'm betting it has the horsepower
Old 09-12-2014, 03:04 AM
AVS Club Gold
renethx's Avatar
Quoted: 241 Post(s)
Liked: 390
I tested Celeron J1900 (finally ). Celeron J1900 supports:
- BR 3D: both MVC hardware-accelerated decoding (30% CPU usage) and frame packing 3D output.
- Quad core is fast enough to decode MVC by CoreMVC in Stereoscopic Player (60% CPU usage).
- Precise 23Hz (at least as precise as Haswell GPU).
- No HD audio bitstreaming under Windows.
renethx is offline
Old 09-13-2014, 12:36 PM
Quoted: 14 Post(s)
Liked: 27
Z97 / H97 chipset motherboards are expensive (and they add nothing, except for M.2 card support). B85 / H81 chipset mb with Celeron G1820 / G1840 is still the cheapest and best. If you want 3D, go with A6-6400K with A88X / A78 mb. Bay Trail-M and D (Celeron N2820, J1800, J1900 etc.) is also reported to support 3D, but only if you want the lowest power system.
From a performance perspective, not just for HTPC use, I am someone who uses google chrome and regularly has about 100 browser tabs open at once, would it be more advisable to choose a Pentium G3258 and overclock it to about 4.6ghz+, but I'd need a more expensive Z/H97 motherboard or use a H81 chipset and Core I3 4360?
I think the 4360 has more powerful integrated graphics, but Pentium should have hardware lanczos dxva scaling? and Vector Adaptive de-interlacing. As for the lack of displayport on H81 motherboards I think there is a programme where I can output the iGPU through the ports of a dGPU.
Is there much of a performance hit from using just 1 8gb Ram module rather than 2x4?
leonccyiu is offline
Old 09-13-2014, 01:00 PM
AVS Club Gold
renethx's Avatar
Quoted: 241 Post(s)
Liked: 390
For lots of browser tabs, (system) memory size matters. Processor speed is irrelevant.
Even Intel HD Graphics in Celeron/Pentium Haswell desktop processor is enough for good deinterlacing and DXVA2 scaling. But Intel HD Graphics 4400/4600 of Core i3/i5/i7 has twice EUs so you will feel more comfortable, say, with madVR.
Yes, 1x8GB is inferior to 2x4GB in many applications, including video playback with madVR.
If you want DisplayPort, I recommend MSI H97M-G43.
renethx is offline
Old 09-13-2014, 02:27 PM
Eugene157's Avatar
Quoted: 137 Post(s)
Liked: 24
Will it work with 4K ?
Eugene157 is offline
Old 09-13-2014, 04:50 PM
mdavej's Avatar
Quoted: 754 Post(s)
Liked: 484
Thanks, man! Lovin' my J1900 10 Watts of awesomeness. Don't need HD audio for cable TV anyway. Got the rest covered by other devices.
Liked the silence so much, I replaced my main desktop with a J1900 too.
mdavej is offline
Asrock , Asrock Z87m Extreme4 Lga1150 Intel Z87 Chipset Ddr3 Quad Crossfirex Quad Sli Sata3 Usb3 0 Microatx M , Intel Core I5 3570 3 4 Ghz Processor , Intel Pentium G2020 2 9ghz Lga 1155 Dual Core Desktop Processor , Intel Pentium G3220 3 0ghz Lga 1150 Dual Core Desktop Processor , Intel , Amd , Amd A10 6700 Richland 4 2ghz Socket Fm2 65w Quad Core Desktop Processor Amd Radeon Hd Ad6700okhlbox , Amd A6 5400k 3 6ghz Socket Fm2 Dual Core Desktop Processor , Amd A8 5600k 3 6ghz Socket Fm2 Quad Core Desktop Processor , Amd A6 3650 2 6ghz Socket Fm1 Quad Core Desktop Apu Cpu Gpu With Directx 11 Graphic , Asus , Asus Computer , Asus Us , Asus Components , Asus Computer International Direct
