Quiet HTPC case for bedroom ??? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 71 Old 04-19-2012, 04:44 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
Originally Posted by assassin View Post
Flexraid erases whatever is stored on the parity drive when you initialize the raid. If you want to use a 3tb data drive (now or later) you have to have at least a 3tb parity drive.
So then the other drives don't get erased ?
So my media will stay intact ?
Mfusick is offline
post #62 of 71 Old 04-19-2012, 04:46 PM
assassin's Avatar
Quoted: 132 Post(s)
Liked: 254
That's correct. The other drives will stay intact AND get pooled into 1 large virtual hard drive that is super easy then to map and share across your network.
assassin is offline
post #63 of 71 Old 04-19-2012, 04:48 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
Sweet!
I can't wait to set up flex raid!
How long did it take you ?
Mfusick is offline
post #64 of 71 Old 04-19-2012, 04:51 PM
assassin's Avatar
Quoted: 132 Post(s)
Liked: 254
Sweet!
I think 4-6 hours or so to build the raid and parity drives.
assassin is offline
post #65 of 71 Old 04-19-2012, 04:59 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
How many hdd can I install before I need a bigger PSU ?
Mfusick is offline
post #66 of 71 Old 04-19-2012, 05:01 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
AsRock h61 with 8gb ddr3 + g530
Might need 100 watts for that ... Lol
I usually figure 25 watts per hdd drive to be safe but honestly have no clue .
I figure I must be good until 10 hdd 's ?
Mfusick is offline
post #67 of 71 Old 04-19-2012, 05:04 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
Originally Posted by moshster View Post
What do you guys think of this for a bedroom HTPC?
http://www.newegg.com/Product/Produc...&SID=u00000687
You can do much better building yourself
Mfusick is offline
post #68 of 71 Old 04-19-2012, 05:20 PM
assassin's Avatar
Quoted: 132 Post(s)
Liked: 254
I would think you could get by easily with a 400w PSU.
Edit: The PSU calculator says minimum 311w so it agrees with me.
assassin is offline
post #69 of 71 Old 04-19-2012, 07:10 PM
coppertubing's Avatar
Cool.
Now about cool. How cool exactly does it run? Can you post some temps?
Temps are listed in my thread - CPU temps at idle are about 38-40 C, 44-46 C during 1080p playback, and 66-68 C at max load (Prime95 running for 30 minutes). I just took a reading using an infrared thermometer on the case lid and heatsinks - in a 23C room, these are reading just about 34C after playing a movie for 30 minutes.
coppertubing is offline
post #70 of 71 Old 04-19-2012, 08:26 PM
dksc318's Avatar
2 platter HDDs are about 10W.
I have a G530T (35W version) on a H67 and 1 HDD, While playing video it burns about 30-32W. PS is 300W 80+.
dksc318 is offline
post #71 of 71 Old 04-20-2012, 05:26 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
Ok- that seems about right. 400watt PSU should last me up until 15+ HDD's.
Sounds good.
Mfusick is offline
Reply Home Theater Computers
