NVIDIA GTX460 'no audio devices installed' - AVS Forum | Home Theater Discussions And Reviews
Old 04-17-2012, 08:34 AM - Thread Starter
sanderdvd's Avatar
Quoted: 163 Post(s)
Liked: 30
Hi guys,
I just bought a GTX 460 card and want to use the high res. audio (DTS-MA/TrueHD bitstream) from the card. I tried to install and reinstall the NVIDIA driver over and over again but I just keep getting 'no audio devices are installed' under sound options. The strange this is that the NVIDIA control panel lets me choose my receiver (Onkyo TX-NR5008) under the setting 'setup digital audio' option 'HDMI'. At my Device Manager there is shown 4x 'NVIDIA High Defenition Audio' under 'Sound, video and game controllers'......
Setup:
Asus GTX460 with 295.73 driver (also tried the latest)
ASrock H61M-ITX board (http://www.asrock.com/mb/overview.nl.asp?Model=H61M-ITX)
Windows 7 64-bit with SP1 and all the latest updates
Latest DirectX version
GTX460 connected to my Onkyo TX-NR5008 AVR with mini-HDMI->HDMI cable
Onboard audio disabled in bios
If more information is needed please let me know.
Hope someone knows the solution for my problem.
sanderdvd is offline
Old 04-17-2012, 08:44 AM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
Originally Posted by sanderdvd View Post
Hi guys,
Setup:
Try with a DVI-HDMI cable/adapter. Is the native resolution of your display device HDTV standard (1080p/i or 720p)?
EDID Overrides (capture, install/uninstall, troubleshooting)
Tulli is offline
Old 04-17-2012, 10:26 AM
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 80
use the adapters that came with your card rather than generic adapters.
MlNDBOMB is offline
Old 04-17-2012, 10:37 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
I had issues with NVIDIAs miniHDMI before myself, so yes, try a DVI-HDMI adapter instead.
Nevcairiel is offline
Old 04-17-2012, 11:34 AM - Thread Starter
sanderdvd's Avatar
Quoted: 163 Post(s)
Liked: 30
I forgot to mention that I am indeed using a miniHDMI->HDMI dongle
Nevcairiel, I thought I read somewhere that it is the best to use the (mini)HDMI output and not the DVI output?
Old 04-17-2012, 11:35 AM - Thread Starter
sanderdvd's Avatar
Quoted: 163 Post(s)
Liked: 30
native resulution of my display is 1080p (projector with HDMI)
Old 04-17-2012, 12:48 PM - Thread Starter
sanderdvd's Avatar
Quoted: 163 Post(s)
Liked: 30
I am using the one that came with the card
Old 04-19-2012, 02:07 PM - Thread Starter
sanderdvd's Avatar
Quoted: 163 Post(s)
Liked: 30
ok guys, you really have to help me out here. I just tried ANOTHER gtx460 card with ANOTHER miniHDMI->HDMI dongle but the high def audio device is still not recognized in the sound control panel and I get 'no audio devices are installed'. Like I said before: my Onkyo TX-NR5008 is recognized in the NVIDIA contro panel under the setting 'setup digital audio' option 'HDMI'. And also in my device manager there is 4x NVIDIA High Defenition Audio.
What there @#@%#@ is going on here........
Old 04-19-2012, 02:15 PM
Tulli's Avatar
Quoted: 117 Post(s)
Liked: 102
The mini HDMI connector is the problem (it never worked for me either). Just connect using any DVI-HDMI adapter or cable instead.
Tulli is offline
Old 04-19-2012, 02:33 PM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
You now read the opposite here, so go try a DVI->HDMI adapter!
Old 04-19-2012, 03:33 PM
maxleung's Avatar
Quoted: 22 Post(s)
I've gotten the mini-HDMI to work on my geforce 560 (not a TI) with my Yamaha RX-A2010. However, this is rather flaky - if I put the PC to sleep and later awaken it, I have a 50% chance that I can never get the audio back!
I found that the DVI ports are more reliable in this regard.
With that said - you *might* want to try the beta NVIDIA 301.24 drivers - it has a new HDMI audio driver that at least fixes the silent stream bug for DirectSound-enabled players (still get a second of silence when unpausing audio in WASAPI or ASIO modes).
EDIT: Oh - the 301.24 drivers breaks MadVR a little - you have to *uncheck* the "use separate device for presentation" checkbox - which could be a big issue!
maxleung is offline
Old 04-19-2012, 04:20 PM
maxleung's Avatar
Quoted: 22 Post(s)
I looked at the files in the C:\\NVIDIA\\DisplayDriver\\301.24\\WinVista_Win7_64\\English \\HDAudio directory versus the ones in C:\\NVIDIA\\DisplayDriver\\296.10\\WinVista_Win7_64\\English \\HDAudio, and 3 files are different:
HDAudio.nvi
nvhda.cat
nvhda.inf
This is odd because, as far as I can tell, the rest of the files (the driver binaries) are identical - so it is possible that the 296.10 HDAudio driver didn't "take" the first time.
maxleung is offline
Old 04-20-2012, 01:11 AM
Tong Chia's Avatar
Was the HDMI input on the AVR setup for both video and audio?
Tong Chia is offline
Old 12-08-2015, 02:18 PM
Hurk's Avatar
Nc 460 No sound
Just got back from 3 week holiday and found no sound whatsoever coming from system. Tried every thing nothing. Reser to factor defaults and nothing. Found that onkyo is o
Honoring warranty fix. I applied to pickup and fix. I take it this is a common problem?
Hurk
Hurk is offline
Old 12-09-2015, 11:52 PM
ikkuranus's Avatar
Quoted: 86 Post(s)
Liked: 53
Hurk
Yes it's common. My tx-nr515 had that issue but I can tell you that I didn't have the no audio device error in windows just a lack of any sound and network connectivity on my avr. Ever since the repair it has been working great.
ikkuranus is offline
