Looking for alternative to E35M1-M Pro - Noise problems - AVS Forum | Home Theater Discussions And Reviews
Old 04-18-2012, 06:38 PM - Thread Starter
nubz69's Avatar
So I built a HTPC using a E35M1-M pro a few months ago. The main parts are
E35m1-m Pro
Silverstone case
Xonar ST + expansion
Seasonic fanless PSU
WD hard drive
From day one I have had the same problem. A switching noise that can be heard on the line out. The reason it is such a problem is that I am using very efficient speakers so every little noise is magnified in the system. Here is everything I have tried to get rid of it.
Replaced PSU - No change
Removed sound card - noise still comes through stock headphone/line out
disconnected power to HD while system is running - No change
replaced MB under warranty - just got it back and no change
I now think that this is a problem that is inherent to this motherboard. I am ready to try something else but I don't want to spend an arm and a leg considering how much I have already had to deal with. Can anyone recommend an alternative that is around the same price point, has PCI and onboard graphics good enough for 1080p?
nubz69 is offline
Old 04-18-2012, 06:58 PM
BLOCKMONSTER's Avatar
I looked and that board costs 120$ so...
GIGABYTE GA-B75M
http://www.newegg.com/Product/Produc...82E16813128540
or if you want HDMI and 8x SATA(!!) then go with this:
ASRock B75M
http://www.newegg.com/Product/Produc...82E16813157313
with
Intel Celeron G530
http://www.newegg.com/Product/Produc...82E16819116409
Looking at 126$. Of course you have to put the processor/heatsink on but should be fine and you get a better CPU.
BLOCKMONSTER is offline
Old 04-18-2012, 08:40 PM
dj4monie's Avatar
Quoted: 37 Post(s)
Liked: 25
Why didn't you RMA it? SMH....
A few options at the same price point -
A4-3300 + ECS A75 Micro-ATX = $117 After Rebate
A6-3500 + Same Board = $126 After Rebate
There a couple of post about sub-$100 Intel G-series based systems.
A. Thomas
PSN - DJFourMoney
dj4monie is offline
Old 04-18-2012, 08:44 PM - Thread Starter
nubz69's Avatar
Here is a clip of the noise recorded using another computer. I have increased the amplitude which is why there is so much hiss. Can someone confirm that this is indeed coming from the motherboard itself? The only things I have not completely R&Red on this rig is the memory and the hard drive but considering the noise is still there when the hard drive is removed from power, I doubt that is the cause. The noise is affected by some processes if that makes a difference.
E35M1 noise.zip 428.2158203125k . file
nubz69 is offline
Old 04-18-2012, 08:54 PM - Thread Starter
nubz69's Avatar
"replaced MB under warranty - just got it back and no change" = RMAed it and the return unit has same problem.
nubz69 is offline
Old 04-20-2012, 10:08 AM - Thread Starter
nubz69's Avatar
Before I go and order my new motherboard, could someone take a listen to the noise and tell me if there is anything else I may want to try first?
nubz69 is offline
Old 04-20-2012, 08:45 PM
kegobeer's Avatar
Have you taken this computer to a different location (friend's house, etc) and tested it? Have you connected it to a different monitor/tv? Have you tried removing everything from the case and running it while the motherboard is just sitting on a board? Hiss is usually related to power and grounding, just like it is when you encounter hiss in a car stereo, and it can also be influenced by feedback from external devices, like a monitor. So, I would try doing all of these things to verify that none of the other hardware is causing it before you buy a new motherboard.
kegobeer is offline
Old 04-21-2012, 12:30 AM
xfett's Avatar
Is the noise random or repetitive ? It kinda sounds like some sort of switching on the power...maybe a leaking/bad capacitor. Could be anything so you need to isolate it to a specific item.
"Man, I told you we shouldn't have shot Niedermeyer"
xfett is offline
