Clean Windows 7 Install using Family Pack - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 04-19-2012, 07:49 PM - Thread Starter
hockeyrcks9901's Avatar
Quick question regarding Windows.
I have two computers, one running Vista and one running XP. I want to upgrade them both to 7, however I want to do it with a new hdd in them. I've read of this being possible with the upgrade disks by installing Windows 7 without activating and then installing it again. I have valid copies of the previous versions, I just want a clean install.
Is this possible ?
hockeyrcks9901 is offline
post #2 of 12 Old 04-19-2012, 07:53 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Google "Windows 7 Double Install Method"
Works very well and recognized by Microsoft as genuine.
assassin is online now
post #3 of 12 Old 04-20-2012, 06:36 AM
josrq's Avatar
I just used an upgrade disk to install Win7HP. Use the custom option for a clean install. This recent install went over a disk w/Win8CP. Activated fine.
josrq is offline
post #4 of 12 Old 04-20-2012, 08:35 AM
doozer12's Avatar
Did you have to format the drive during install? (lose all data)?
doozer12 is offline
post #5 of 12 Old 04-20-2012, 08:44 AM
drtdiver's Avatar
as long as the drive has had windows on it at least once an upgrade disk can be used to do a clean install without having to jump through any hoops to activate. you can format the drive and do a clean install then activate with no problem.
drtdiver is offline
post #6 of 12 Old 04-20-2012, 08:45 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
I have used "upgrade discs" and it installs fresh to a blank drive.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #7 of 12 Old 04-20-2012, 12:56 PM
tgrinch's Avatar
Quoted: 21 Post(s)
I've used an upgrade disc w/out issues too. After install, there was a single registry setting and comand line I ran and that was it. As Assassin mentions, double install method works too.
tgrinch is offline
post #8 of 12 Old 04-20-2012, 02:50 PM
bjterry62's Avatar
Is this possible ?
Yes it is possible. One difference with the family pack though is that it will not work with the double install method. It will look like it is working, but when it asks for your key, it will not accept it. Individual purchased upgrades will work though.
However, you can get your clean install on a new drive. You need to clone your old installation to the new drive. Put the new drive in the PC and then run the Win 7 upgrade process. It will ask if you want to do an upgrade or clean install once you get started. Save your old HDDs so you will have your old files and can transfer them to the new hdd.
BT
Just remember, to the MPAA "We're all guilty until..............."
bjterry62 is offline
post #9 of 12 Old 04-20-2012, 02:55 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I have used the family 3 pack upgrades using the the double install method just fine. Its been a while though.
post #10 of 12 Old 04-20-2012, 03:06 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
+1 and recently (for Mom's eBay/Facebook build)
StardogChampion is offline
post #11 of 12 Old 04-21-2012, 05:52 AM
bjterry62's Avatar
Every time I've tried the initial install on a clean drive, I get the invalid Key message after entering the key. I can through my old retail copy of vista or xp on there though and it will install fine. Maybe it was just mine, but I tried it multiple times on different PCs.
YMMV
BT
post #12 of 12 Old 04-21-2012, 07:41 AM
josrq's Avatar
I had no data to save just the Win8CP OS. Oh, and no manual format, just install the install disk and follow the prompts.
josrq is offline
Reply Home Theater Computers
