resolution with VGA cable is 1920x1080 HDMI is 1366x768 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-22-2012, 07:09 AM - Thread Starter
stevethebrain's Avatar
Quoted: 104 Post(s)
Liked: 25
Samsung P2770HD TV used as computer monitor.same issuse w/ large Samsung.
initially plugged in a VGA cable into the 2770 (w/ old Laptop XP OS) res. was 1920x1080 nice and clear.
I'm now using a newer lap top Win7 (and have also connected a newer desktop Win7) w/ a HDMI cable and both only get 1366x768.
I now have a one " border on top and bottom and about a half" on both sides effectively reducing the size of my display.
I don't mine changing back to a VGA cable for my PC work station. however this is'nt a option for my Samsung PN58C500 Plazma I need a HDMI from computer to AVR for remote controlling.
I have right click on desktop click screen resolution and have res set to maxium.
Please tell me there's a solution for the devils that reduced the size of my TVs.
Thanks STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #2 of 8 Old 04-22-2012, 07:17 AM
pokekevin's Avatar
Liked: 102
Are you set to only output to the tv or both(monitor and tv)
pokekevin is offline
post #3 of 8 Old 04-22-2012, 08:33 AM - Thread Starter
Quoted: 104 Post(s)
Liked: 25
I have 2 indepenant sys. 1 is my work station 2 is the home theater.
should have asked about each individualley.
however it's the same situation on both.
Thanks STB
post #4 of 8 Old 04-22-2012, 08:33 AM
rockytt's Avatar
Often when plugging in via HDMI, the monitor overscans the image-hence your issue.
Bunch of stuff in here about setting overscan to zero - IIRC it involves using Input 2 and renaming it to "PC", or something like that. (Take a peek through here and you'll find it. It comes up a few times a week)
rockytt is offline
post #5 of 8 Old 04-22-2012, 09:05 AM
hirent's Avatar
Thanks STB
What video card is driving these displays?
Are all your drivers up to date?
hirent is offline
post #6 of 8 Old 04-22-2012, 09:20 AM - Thread Starter
Quoted: 104 Post(s)
Liked: 25
I3 CPU for video, yes updated drivers
I should have mentioned during initial setup w/ old LT that LTs screen was burned up so I never knew if it was attempting to turn on.
Thanks STB
post #7 of 8 Old 04-22-2012, 09:24 AM - Thread Starter
Quoted: 104 Post(s)
Liked: 25
Kevin I don't see a way to have only one output either monitor or TV
BTW nice setup you have there.
post #8 of 8 Old 04-22-2012, 11:09 AM
hirent's Avatar
In Windows Display Properties; click on Advanced Settings, then click Monitor and uncheck the box that says 'Hide modes that this monitor cannot display'.
If that doesn't work try this next:
Under Intel's Graphics Driver Utility, click on 'Custom Resolutions' and see if you can set the 1080p resolution.
hirent is offline
Reply Home Theater Computers
