MCM and/or MB not scraping properly? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 04-24-2012, 09:40 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I've noticed lately that I am not getting the movie plot or synopsis showing in Media Browser. I also noticed an error message on the log screen of Media Center Master saying something about not having access to a file on my system last night but it was late so I didn't copy/paste the message (it wouldn't let me do it!) and I was too tired to write it down..
Has anybody else experienced this? I'm using the free version of both programs.
Sammy2 is offline
post #2 of 13 Old 04-24-2012, 11:49 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Are you guys sleeping today?
I thought for sure you'd have it all figured out for me by now..
Sammy2 is offline
post #3 of 13 Old 04-24-2012, 02:31 PM
cdru's Avatar
Quoted: 20 Post(s)
I would look into ownership and permissions of the directory and/or file. I had similar problems before for files that were acquired by programs running as services.
cdru is offline
post #4 of 13 Old 04-24-2012, 03:10 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
The mkv files are on my PC and not the HTPC. They are root-shared network drives that are mapped on the HTPC.
Sammy2 is offline
post #5 of 13 Old 04-26-2012, 09:38 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
So nobody else is having this problem?
Should I un-install/install MCM?
Sammy2 is offline
post #6 of 13 Old 04-26-2012, 10:14 AM
bimmerfreak0's Avatar
Quoted: 12 Post(s)
I have never had this problem. However, I have had to uninstall, re-install MCM multiple times for other "annoying" issues. Try that first.
bimmerfreak0 is offline
post #7 of 13 Old 04-26-2012, 10:34 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
What annoying issues would those be?
Sammy2 is offline
post #8 of 13 Old 04-26-2012, 08:57 PM
Quoted: 12 Post(s)
For a while I had it where all the new movies that were *ahem* installed after March would have all their metadata, files, pictures and backdrops. But MCM would show them as "yellow"...which means no nothing in the file. I would be able to do the "refresh metadata" and violia...all the metadata was there! Also, always had issues with getting TV shows recognized. And you can forget about boxsets. You have to have them in individual folders in the "main" folder first...find the metadata in MCM and apply it. Then manually move the movies into the "collection" folder. Then, for some reason, MCM will recognize the movies as a "collection.
It's just stupid things. However, it is free.
post #9 of 13 Old 04-26-2012, 09:12 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
So you did the refresh after an un-install and re-install?
Or should I just do a refresh?
Sammy2 is offline
post #10 of 13 Old 04-27-2012, 08:10 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
For some reason a bunch of permissions were changed (or just flat out gone) on my network when I checked this morning. I've re-established them but had to head off to work. So maybe tonight I'll have time to reboot and see what happens.
Apparantly the ability to read the HDD was available in both MCM and MB but the writing permission was lost.
I'm a little perplexed as to why tis would happpen. I'm wondering if MSE or MS Defender decided on their own that my permissions were to liberal and changed them for me.
Sammy2 is offline
post #11 of 13 Old 04-27-2012, 04:03 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Still failing and here's the message:
"Aborted: I do not have access to the Windows Media Center DVD cache located in C:\\Users\\HTPC\\AppData\\Roaming\\Microsoft\\eHome".
Will a re-install give me this back?
A folder called DvdInfoCache exists in that folder?
Sammy2 is offline
post #12 of 13 Old 04-27-2012, 04:25 PM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
IDK, but it seems to be working now, other than the incorrect aspect ratio..
I forced a refresh and it worked. Just buggy I guess but what do you want for nothin? A rubber bisquit?
Sammy2 is offline
post #13 of 13 Old 04-28-2012, 09:35 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Maybe not. There's no folder art or movie.xml in the folder but the info showed up in MB? I should add that I did a manual refresh of the MB service from the taskbar.
Sammy2 is offline
Reply Home Theater Computers
