Problems with Multichannel Sound via HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-25-2012, 02:04 PM - Thread Starter
wuerrer's Avatar
Hi,
I need help with the following please:
I have connected a HTPC (Zotac Zbox AD05, AMD RADEON 6320, Win 7 Ultimate x64) via HDMI with my AVR (Denon 3808). Unfortunately I do not recieve any kind of multichannel sound.
As long as the windows settings are on stereo I recieve DD2.0, once I change the settings to multichannel (5.1 or 7.1) I only recieve "normal" stereo (not even DD).
I have tried the following players: VLC, XBMC, WinMediaPlayer
I have tried it with video (DD5.1 and DTS) and audio (DTS and DTS-HD) files. Always the same result.
Drivers:
ATI Catalys (as of today I am not sure about the version)
Realtek High Definition Audio R 2.68 for Win 7 x64
Any ideas?
Stefan
wuerrer is offline
post #2 of 9 Old 04-25-2012, 02:31 PM
hirent's Avatar
Originally Posted by wuerrer View Post
Drivers:
Do you have audio pass-through enabled in your AVR?
If so, the HTPC is seeing the two TV speakers. Turn it OFF.
No need of Realtek drivers. Use the HDMI driver in the CCC package.
Then click on 'Playback Devices' (vol. control) and configure the HDMI device for 5.1/7.1 sound.
hirent is offline
post #3 of 9 Old 04-26-2012, 02:38 AM - Thread Starter
wuerrer's Avatar
Thanks for the reply.
Pass through is dissabled on the AVR. Sound never comes through the TV but always through the speakers of the 5.1 System.
I only installed the Realtek drivers because they came with the Zotac. I will try to deeinstall them tonight.
I just found out that every Stereo signal (no matter if DD or not) gets treated correct by the AVR, but once the software on the HTPC recognises multichannel sound (DD, DTS) it seems that the multichannel does not reach the AVR as it does not switch to the correct format but treats it always like a stereo signal.
BR
Stefan
Do you think it still could be a pprobelm with the EDID altough Sound and Video works basically?
wuerrer is offline
post #4 of 9 Old 04-26-2012, 12:53 PM - Thread Starter
wuerrer's Avatar
I tried the edid override as well as the ati drivers without the realtek ones. Unfortunately the results are the same.
Any ideas?
wuerrer is offline
post #5 of 9 Old 04-26-2012, 12:55 PM - Thread Starter
wuerrer's Avatar
As I said once i change to 5.1 the signal apears to be stereo only
wuerrer is offline
post #6 of 9 Old 04-26-2012, 12:58 PM
James_stewart's Avatar
Any ideas?
I may be wrong here, but don't you have to enable passthrough within these players? Instead of choosing the multi-channel options, don't you have to manually select spdif/hdmi passthrough?
James_stewart is offline
post #7 of 9 Old 04-26-2012, 12:59 PM
hirent's Avatar
Do you see 'AMD High Def. Device' in Playback Devices?
What codecs are listed under its properties?
hirent is offline
post #8 of 9 Old 04-26-2012, 01:11 PM - Thread Starter
wuerrer's Avatar
I see the AMD HD Device and nearly all DD / DTS Formats are Listed.
But I just found out what is the reason for the problem:
If the DENON AVR is in "detect imput signal automaticly" mode the AVR does not realise the change from "multichannel" (in windows) to DD5.1 or DTS. Once I changed this, everything works fine.
However thanks a lot for your help.
BR
Stefan
wuerrer is offline
post #9 of 9 Old 04-26-2012, 02:35 PM
hirent's Avatar
BR
Stefan
Oh well, you learn something new everyday.
Good that you posted the solution here.
All too often, people solve their issues and never report back. This might help someone else, somewhere down the line.
hirent is offline
Reply Home Theater Computers
