HTPC header on newer Intel mainboards - what can you do with it? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 04-26-2012, 03:10 AM - Thread Starter
TOMillr's Avatar
I've just upgraded my Win7-based MC with a new Intel DH61AG which comes with a "htpc" labeled header on the mainboard which I've never seen before. The manual only provides information on the pin layout but doesn't say anything about what this port is actually used for:
Especially the "recording_led" thing makes me curious... Does anyone have some informations on how this header works? Do I need some piece of software to have it work with the MC software itself?
TOMillr is offline
post #2 of 13 Old 04-26-2012, 05:56 AM
sbermunk's Avatar
I just got a DH77DF board that has the same header, and I was wondering also...
sbermunk is offline
post #3 of 13 Old 04-26-2012, 06:21 AM
hirent's Avatar
It is used for HDMI-CEC connections.
"Besides the consumer IR (CIR) header found on other Intel Media Series boards which supports an internal Microsoft eHome IR receiver, the DH61AG also includes two other connectors that position it perfectly for HTPC use. The first is the appropriately named “HTPC” header which can be used to enable the “RECORDING_LED” feature as well as the much more interesting potential for HDMI CEC device control from the PC. Like the CIR header, third-party hardware will be required to enable CEC, but for those who are interested in the RECORDING_LED’s simple on/off status indicator LcdWriter supports it currently. Unfortunately the CEC controller hardware is not yet available from third party suppliers so the feature went untested; hopefully this omission can be corrected shortly."
Here, read the full review; Intel DH61AG
Review of the USB CEC Adapter. Especially read the last page.
Edit: Interesting possibility here:
"For pre-built HTPCs like the ASRock Core series or Vision 3D series / Zotac ZBox series, the manufacturers could get rid of the MCE remotes and integrate CEC functionality in the system (for control through the TV remote). In the higher end systems, they could optionally bundle in the Motorola Nyxboard Remote for full home theater control through the HTPC."
hirent is offline
post #4 of 13 Old 04-26-2012, 06:45 AM
doozer12's Avatar
I would get one just for the rec LED. A simple, unnecessary thing, but one I wish I had.
doozer12 is offline
post #5 of 13 Old 04-26-2012, 08:10 AM
Diverge's Avatar
I just hooked up an LED to the Recording LED pins of the HTPC header on a DG61AG, but I couldn't get it to work. Anyone else try it?
I'll try swapping the polarity when I get home (just incase my case is wired backwards).
Diverge is offline
post #6 of 13 Old 04-26-2012, 11:13 AM
SAM64's Avatar
Liked: 78
The "recording LED" pin is active low. Use a current limiting resistor as well.
SAM64 is offline
post #7 of 13 Old 04-26-2012, 11:28 AM
Diverge's Avatar
K, thanks. I'll give it a try when I get home.
Diverge is offline
post #8 of 13 Old 05-13-2012, 06:29 AM
makryger's Avatar
You can use the HDD light as a recording LED- no extra htpc header necessary. Works on almost any motherboard. Just download LEDSDriver.
makryger is offline
post #9 of 13 Old 05-13-2012, 02:02 PM
Smitty2k1's Avatar
Wow that looks very cool, I've never even thought about custom LED indicators and control before... hmmmm....
Smitty2k1 is offline
post #10 of 13 Old 05-14-2012, 04:25 AM
hirent's Avatar
Learned something new today.
hirent is offline
post #11 of 13 Old 05-15-2012, 02:55 AM
ZombieTheater's Avatar
LED driver is pretty cool. Here is how I set mine up. First my case came with 2 blue LEDs, I replaced one with a red LED. On my MB there was a choise for LED power or LED standby. I used standby and changed a setting in the BIOS, this allowed the red LED to activate only when in S3 and keeps it on solid(no flashing) and off when the HTPC is on. I did this because it matches the way the TV's LED works(off=red led on, on=led off) The second LED(blue) got connected to an internal comm port that the LEDSDriver controls. I set this one to flash rapidly if the HTPC is muted, flash slowly if it woke up for an automated task(recording/updates) or if it is in away mode, its off the rest of the time.
ZombieTheater is offline
post #12 of 13 Old 05-30-2012, 06:04 AM
pittsoccer33's Avatar
Quoted: 650 Post(s)
Liked: 432
are there some cases that are primed to take advantage of this?
i am also having trouble finding cases with ir receivers built into them. for me it is either that or buying one with a 3.5" external bay and buying an imon receiver.
is everybody else really just using usb based ir receiver that sit outside the case?
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #13 of 13 Old 02-16-2013, 02:48 AM - Thread Starter
TOMillr's Avatar
I've just noticed that there's a small utility on the Intel site which triggers the recording_led port when Windows Media Center is recording something:
Intel Recording LED Driver
Did anyone give this a try already?
TOMillr is offline
Reply Home Theater Computers
