Help installing WHS to a 60GB SSD drive ? cfg.ini root ??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 30 Old 04-26-2012, 07:28 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
Instructions
1. Remove all Hard Drives currently connected to you system with the exception of the targeted SSD or traditional SATA Drive that will be used for either your WHS 2011 Operating System .
NOTE - Remember to insure all previous Data you want saved from the targeted drive is removed before installation or it will be permanently lost.
2. Format an NTFS USB Flash Drive, and create a file on it using notepad in the root called cfg.ini. (Insure there is nothing else on the USB)
3. Open the cfg.ini in notepad or any other text editor
4. Cut and Paste the following into the cfg.ini file below
[WinPE]
ConfigDisk=1
CheckReqs=0
WindowsPartitionSize=MAX
5. Close the file and save it on the USB Flash Drive.
6. Insert the USB Flash Drive with the cfg.ini file into the targeted WHS 2011 Server's empty USB Slot.
7. Power up your Server and insure that either your Windows Home Server 2011 install DVD has been inserted into your Servers ROM.
8. Once your Server has booted off the install DVD the Installer will read the CFG.ini file and begin the automated install process. There should be NO User Input required during this time.
9. When your Server Installer has finished its first part of the Install and goes to reboot for the 1st time REMOVE the USB Flash Drive and the Install DVD from your Server BEFORE your server boots back up ( As shown below). This will allow the Server upon rebooting to find your hard drive and continue the installation from there without further interruption.
10. No Further action on your part will be required and the rest of the install will finish automatically, again without any user intervention.
11. Once the installation has completed please plug in any other drives and continue with completing your server build.
Guys I need help. I am having issue installing with this method. I am not sure what I am doing wrong.
I took a USB3.0 8GB stick- formatted it NTFS- then I named a wordpad document cfg.ini and saved it to the USB stick. IT is the only file on the USB stick.
I opened it up- copied and pasted:
[WinPE]
ConfigDisk=1
CheckReqs=0
Then saved it again to the USB stick. I verified it was there, then inserted it into my Server motherboard.
The only drive I have hooked up is a 60GB SSD drive, and also a SATA DVD drive to install the DVD install disc from.
The instructions say no user input required. But when I boot up it goes to the screen asking me for new or existing install.
If I choose NEW then it gives me an error message. I assume the error is that the drive is too small.
HELP ???
Idea?s
Mfusick is offline
post #2 of 30 Old 04-26-2012, 08:06 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
NO help AVS???
Mfusick is offline
post #3 of 30 Old 04-26-2012, 09:47 PM
David Dias's Avatar
Yeah, that won't work... you need to copy the contents of the WHS install disc onto the USB drive, then place the cfg.ini on the root of the USB drive. But first you have to make the USB drive bootable, the instructions to do this are just a google search away.
Your cfg.ini looks good though, I added the serial# and some other stuff to mine:
[WinPE]
CheckReqs=0
PID=WHS serial #
ConfigDisk=1
[InitialConfiguration]
ServerName=your server name
Settings=All
PlainTextPassword=your server pw
PasswordHint=password hint
David Dias is offline
post #4 of 30 Old 04-26-2012, 09:49 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
Hmmm none of the instructions I am finding say I should copy the install DVD to the USB.
Is that what you did ?
Mfusick is offline
post #5 of 30 Old 04-26-2012, 09:52 PM
David Dias's Avatar
Yes and it worked. I used a 60GB SSD for WHS 2011.
post #6 of 30 Old 04-27-2012, 03:41 AM
StanF's Avatar
Use this tool first:
http://www.microsoftstore.com/store/...usbdvd_dwnTool
Then, add your .ini file...
One quick note...after you boot from the USB key and run the installer, the installer will modify the .ini file. You will have to edit the .ini file before you try to boot from it again. It adds some setting like "Parse cfg.ini=N", which will cause it to skip the .ini file the next time you try to use it. It's been a while since I did this, so I don't remember the exact line.
StanF is offline
post #7 of 30 Old 04-27-2012, 04:27 AM
bryansj's Avatar
Quoted: 1333 Post(s)
Liked: 625
I did the cfg.ini file to USB and the install from DVD and it worked.
It looks like you posted the same guide that I followed.
http://connecteddigitalworld.com/201...er-than-160gb/
Your file is called cfg.ini and not cfg.ini.txt?
bryansj is online now
post #8 of 30 Old 04-27-2012, 06:23 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
Yeah.
I think so.
Can you clarify what "in the root" means?
I saved a notepad doc on The empty USB drive and named it cfg.ini
Then I opened it and copied the above and save it again. Then moved it to the server and tried installing.
Each time it loads from DVD and brings me to set up screen showing my SSD drive. If I choose that drive it fails.
My understanding was that the cfg.ini file on the USB should make the install skip this screen ? Yes ?
So. Either my file is wrong ? Or my bios settings are. Do you set boot priority to DVD Sata? USB ? Or SSD ?
Mfusick is offline
post #9 of 30 Old 04-27-2012, 06:59 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
So you mean if I try to use the USB stick again for another installation ?
Or do you mean upon system restart as part of the original install ?
Mfusick is offline
post #10 of 30 Old 04-27-2012, 07:29 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
That it's named cfg.ini.txt is the first thought that comes to my mind too. Notepad is notorious for doing that. One way to avoid that is open a command prompt in the root of the USB drive and type 'notepad cfg.ini'. Then it'll ask you if you want to create it. When you save it won't tack on the .txt.
StardogChampion is offline
post #11 of 30 Old 04-27-2012, 08:54 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
Explain this a little more.
How do I open a command prompt in the root of the USB?
Mfusick is offline
post #12 of 30 Old 04-27-2012, 09:35 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
Well- I have a Patriot USB3.0 8GB stick. I formatted it NTFS quick format method. I opened notepad and selected SAVE AS and named the file CFG.INI
When I look back it just shows as cfg
But if I click properties it looks like ini is there.
check this out:
What am I doing wrong?
Mfusick is offline
post #13 of 30 Old 04-27-2012, 10:00 AM
DeanM's Avatar
Do yourself a favor and go into Windows Explorer, Organize, Folder and Search Options, View, and uncheck in advanced settings "Hide extensions for known file types."
This, IMO, is the dumbest default setting that Windows explorer has. Not only is it confusing and makes dealing properly with file extensions difficult (because they are hidden), but I think it is dangerous. Changing this default is the first thing I change on any new Windows install.
DeanM is offline
post #14 of 30 Old 04-27-2012, 10:25 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
Mfusick is offline
post #15 of 30 Old 04-28-2012, 09:24 AM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
your not putting it in a usb 3 slot are you? Windows needs extra drivers for usb 3
Andy_Steb is offline
post #16 of 30 Old 04-28-2012, 02:50 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
I did try that. . Also a 2.0 slot too
Mfusick is offline
post #17 of 30 Old 04-28-2012, 05:16 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
I got it to work with f10 hack
Mfusick is offline
post #18 of 30 Old 04-30-2012, 10:33 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
As soon as you are greeted with the screen asking if you want a new install or to repair a previous one push Shift + F10 to bring up cmd.
Type "notepad.exe" without quotes then click file open and browse to sources/SKU/SERVERHOMEPREMIUM.def (you may have to select all files at the bottom so you can see the .def file).
From inside here you can change your amount of ram, number of cpu cores, HDD space, and processor speed to suit your needs. Save and close notepad.
Type "wpshell.exe" without quotes and hit enter => setup will restart with the new parameters.
Mfusick is offline
post #19 of 30 Old 10-09-2012, 02:31 PM
Mick Ebbs's Avatar
I had all sorts of problems, turns out my PC wouldn't read the USB stick whilst booting. I think this is to do with the fact that my motherboard does not allow USB booting either. Fix was to use both CD drives with the cfg.ini file in the second drive. Now works great. Good luck everyone.
Mick Ebbs is offline
post #20 of 30 Old 10-09-2012, 02:33 PM
assassin's Avatar
Quoted: 155 Post(s)
Liked: 261
For those of you who use my server guides I am working on a guide for this issue. I will have 2 ways to use a drive smaller than 160GB.
assassin is online now
post #21 of 30 Old 10-11-2012, 04:32 AM
captain_video's Avatar
Quoted: 524 Post(s)
Liked: 341
I installed WHS on a 320GB drive. After it was installed I couldn't help but notice that WHS split the drive into two separate partitions. The OS was installed on a 60GB partition with the remainder of the drive used for the 2nd partition. My plan is to simply clone the OS partition to a 64GB SSD and make it bootable.
Is it me or does it seem strange that WHS requires you to use a 160GB drive as a minimum but only uses the first 60GB? The OS only occupies about 20GB of the first partition so 60GB is obviously more than ample capacity for the installation. Just another one of those annoying features that Microsoft includes at no extra cost.rolleyes.gif
captain_video is offline
post #22 of 30 Old 10-11-2012, 05:51 AM
assassin's Avatar
Quoted: 155 Post(s)
Liked: 261
Guides are done. Enjoy.
post #23 of 30 Old 10-12-2012, 08:57 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
It's not you.
it does require a 160GB.
But it's pretty easy to open the window and edit the file size limit. I made mine 30GB instead and it worked great.
Very easy infact. I reinstalled once again later for another reason- and it installed on my 60GB SSD.
I picked up a cheapo $44 Agility SSD for the boot drive in my server and it works great.
Mfusick is offline
post #24 of 30 Old 10-12-2012, 09:10 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
You need two ways.
One way worked for me the first time.
The second method was required the second time.
It made no sense to me at the time, but it worked and was easy enough.
Mfusick is offline
post #25 of 30 Old 10-12-2012, 09:19 AM
assassin's Avatar
Quoted: 155 Post(s)
Liked: 261
Originally Posted by Mfusick View Post
You need two ways.
I have a guide now for both ways.
post #26 of 30 Old 04-19-2013, 03:50 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
Dug this up looking for the F10 hack... For some reason the USB method never works for me.
Mfusick is offline
post #27 of 30 Old 07-12-2013, 03:17 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
http://www.avsforum.com/t/1438027/planning-to-rebuild-my-20tb-whs-flexraid-server-information-requested/1100_100#post_23522296
Windows 7 Home Premium 32Bit:
http://msft.digitalrivercontent.net/win/X17-58996.iso
Windows 7 Home Premium 64Bit:
http://msft.digitalrivercontent.net/win/X17-58997.iso
Windows 7 Professional 32Bit:
http://msft.digitalrivercontent.net/win/X17-59183.iso
Windows 7 Professional 64Bit:
http://msft.digitalrivercontent.net/win/X17-59186.iso
Windows 7 Ultimate 32Bit:
http://msft.digitalrivercontent.net/win/X17-59463.iso
Windows 7 Ultimate 64Bit:
http://msft.digitalrivercontent.net/win/X17-59465.iso
If your trying to install Windows home server to SSD smaller than 160GB here is how I do it:
Hit SHIFT +F10 to bring up command prompt. Then type : notepad.exe and hit enter. This will bring up the Notepad. Click file then open and browse to SKU/SERVERHOMEPREMIUM.def. You need to select all files at the bottom, and not just word files to see it. Then just edit the size of the HDD from the 160GB to anything you want it to be. Save and Close.
Then just type wpshell.exe and enter... set up will continue on your drive under 160GB smile.gif
Mfusick is offline
post #28 of 30 Old 08-30-2013, 07:23 PM
jdmag00's Avatar
Thanks Mfusik this saved me, the USB trick just did not want to work, the shift+f10 was a huge help! DAMN YOU MS FOR YOUR DUMB RULES!
jdmag00 is offline
post #29 of 30 Old 08-30-2013, 07:45 PM
assassin's Avatar
Quoted: 155 Post(s)
Liked: 261
I have all of this as an easy reference in my (now free) guides fwiw.
post #30 of 30 Old 08-30-2013, 08:06 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2695
I am not a fan of the USB method. I would recommend you never use it. F-10 hack works every time for me. I also had trouble with the USB method (I tried it first)
Mfusick is offline
Reply Home Theater Computers
