Possible to install Windows PRO from USB drive? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 167 Old 08-20-2012, 01:00 PM
Sammy2's Avatar
Quoted: 515 Post(s)
Liked: 250
I have found that Acronis is more efficient in doing the back up than W7 was. By "efficient" I mean "faster".
Sammy2 is offline
post #92 of 167 Old 10-22-2012, 11:34 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
Anyone make a USB install stick that has the updates and additional programs like ADOBE reader, Firefox and stuff... all built into the windows install ???
Mfusick is offline
post #93 of 167 Old 10-22-2012, 09:28 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
Yes. It even prompts you for computer name, user name, activation key, etc. the first time you boot the system. There are Microsoft tools for doing this which sound intimidating but are actually very easy to use. I loosely followed this: http://technet.microsoft.com/en-us/library/ee523217(v=ws.10).aspx. You can even generalize it so it'll install on different hardware.
StardogChampion is offline
post #94 of 167 Old 12-15-2012, 09:16 AM
pman555's Avatar
Quoted: 42 Post(s)
Does anyone know if there is an ISO to download for Windows 7 Enterprise?
EDIT: Thanks Mfusick!
pman555 is offline
post #95 of 167 Old 12-15-2012, 09:19 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
x64 PRO:
http://msft.digitalrivercontent.net/win/X17-59186.iso
x64 Ultimate:
http://msft.digitalrivercontent.net/win/X17-59465.iso
Mfusick is offline
post #96 of 167 Old 12-15-2012, 09:25 AM
pman555's Avatar
Quoted: 42 Post(s)
Is Enterprise different from Pro or Ultimate or are they the same?
I have a key for Enterprise...
pman555 is offline
post #97 of 167 Old 12-15-2012, 09:37 AM
pman555's Avatar
Quoted: 42 Post(s)
I did some researching and it looks like Enterprise keys and Ultimate keys are different.
I'm going to see if I can create an ISO using the Enterprise disk I have, I was just hoping to be able to skip that step and just download an ISO.
pman555 is offline
post #98 of 167 Old 12-15-2012, 10:17 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
I thought PRO and ENTERPRISE are the same thing with USA and EUROPE names ??
yes or no ?
Mfusick is offline
post #99 of 167 Old 12-15-2012, 10:18 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
I am pretty sure if you install PRO and call MS and tell them your enterprise key is not working they would just give you a legit pro key btw...
I've done things like that before.
As long as your in the system or have registered products before- or own a legitimate product that is like they usually just help you.
Mfusick is offline
post #100 of 167 Old 12-15-2012, 12:15 PM
pman555's Avatar
Quoted: 42 Post(s)
yes or no ?
Nah, I don't think they are the same thing.
I think I'm just going to go the more sure route and make an ISO out of the disk I have.
pman555 is offline
post #101 of 167 Old 12-15-2012, 12:52 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
how do you plan to make an ISO ?
Mfusick is offline
post #102 of 167 Old 12-15-2012, 01:09 PM
captain_video's Avatar
Quoted: 521 Post(s)
Liked: 339
Is there an echo in here? You can make an iso out of any set of files using ImgBurn, UltraIso and several other similar apps.
captain_video is offline
post #103 of 167 Old 12-15-2012, 03:27 PM
pman555's Avatar
Quoted: 42 Post(s)
What he said :-)
I wasnt sure exactly how I'd do it, but I know it can be done, so I was just going to google it.
pman555 is offline
post #104 of 167 Old 12-16-2012, 05:13 AM
aliaskary77's Avatar
Quoted: 46 Post(s)
Liked: 56
my key is for a win7 pro upgrade disc. my disc is not sp1 though. i had issues trying this last year because i downloaded a win7 pro sp1 full. i tried to slipstream sp1 into my upgrade image but no luck.
are there win7 pro sp1 "upgrade" images available online?
aliaskary77 is offline
post #105 of 167 Old 12-16-2012, 07:17 AM
Quoted: 521 Post(s)
Liked: 339
There are full images of Win 7 with SP1 available to download via torrents and newsgroups, but they're not legit. I'm not sure if there are any retail upgrade versions that include SP1. You should be able to install the basic upgrade version and then keep running Windows Update until it's current. I believe you can also download SP1 as an iso and burn it to a CD or DVD and run the upgrade from the disc. You'd still have to run Windows Update to get anything that's been released since SP1, which is quite a lot.
post #106 of 167 Old 12-16-2012, 08:26 AM
ND40oz's Avatar
Yeah, they aren't the same thing. Enterprise is only volume licensed and is basically Ultimate with different licensing. The only place you'll find the isos is on the volume licensing site, technet or msdn. I think you can use the trial version and activate it if you have a MAK code or KMS server. http://technet.microsoft.com/en-us/evalcenter/cc442495.aspx I'm assuming you have a MAK to activate it, it's usually good for hundreds of activations, depends on your licensing agreement with MS.
Edit: actually looks like the trial is only good for 90 days and they embedded the key, I guess you could try editing the key before install or try changing it after the fact, probably easier to just make an ISO from your disk though.
ND40oz is offline
post #107 of 167 Old 12-16-2012, 01:09 PM
Quoted: 46 Post(s)
Liked: 56
Yep, thats what I do now, but would have been nice to skip having to do SP1 though.
post #108 of 167 Old 12-17-2012, 05:25 AM
Quoted: 521 Post(s)
Liked: 339
I like to create a backup image of my OS drive after installing Windows 7, all the upgrades, and the latest drivers before installing anything else. I'll use something like EaseUS Disk Copy to clone the OS partition to a spare drive and then put it away for safekeeping. If I ever need to do a reinstall then I simply copy the drive over and reinstall whatever software I need to bring it back up to the current configuration. Sometimes, after installing all software and device drivers for installed hardware, I'll do another backup once I've used it for a while and determine everything is stable. This allows me to restore a corrupt setup in a quick and painless manner.
post #109 of 167 Old 12-17-2012, 06:08 AM
Quoted: 46 Post(s)
Liked: 56
Yep same way. I have Acronis images for "clean" OS install after all updates with activation, a "basic image" with all drivers and core apps, and a "current" image that i overwrite every month.
When changing hardware though, i will recreate all of those images.
post #110 of 167 Old 12-18-2012, 06:19 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
Acronis is is free how ?
Mfusick is offline
post #111 of 167 Old 12-18-2012, 06:38 AM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 920
Got a SeaGate or WD drive (even an external)? It just needs to be hooked up, it doesn't have to be involved in the transfer. Those brands (maybe others too) offer a free branded version.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #112 of 167 Old 12-18-2012, 02:17 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
I have about 20 of them... lol
Mfusick is offline
post #113 of 167 Old 12-21-2012, 06:14 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
Is it full version or stripped down ?
Mfusick is offline
post #114 of 167 Old 12-22-2012, 05:56 PM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 920
AFAIK full. I've used the WD version a bunch of times and didn't notice anything missing.
olyteddy is offline
post #115 of 167 Old 12-26-2012, 08:24 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
You think I could use it to move an OS install for my TIVO OS from one drive to another ???
Mfusick is offline
post #116 of 167 Old 12-26-2012, 05:25 PM
Quoted: 521 Post(s)
Liked: 339
No, you need to use one of the Tivo-specific Linux distros or WinMFS for installing or cloning a Tivo OS. There's lots of info on it posted at the Tivo Community Forum. Make sure you're using the proper backup and restore app for your particular model because they've changed over the years.
post #117 of 167 Old 12-27-2012, 07:07 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
Is it possible to add or get the OS later ?
Right now I'm much more interested in stealing the 2tb green drive from the TiVo than I am making it operational.
I'd like to sell the TiVo cause I don't use it anymore. I'm thinking its worth more working than without a drive.
That green 2tb is near new and worth $80. I'm not sure what the TiVo is worth but I'd hate to sell it for $100 with drive.
Mfusick is offline
post #118 of 167 Old 12-27-2012, 07:08 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2688
I guess I'm asking if I don't clone the OS now can I obtain it later ?
Mfusick is offline
post #119 of 167 Old 12-27-2012, 06:18 PM
Quoted: 521 Post(s)
Liked: 339
If you're referring to the Tivo OS you can purchase a copy of InstantCake that contains a backup image from DVRUpgrade for the sum of $40, assuming you have a compatible model. I highly recommend making a backup image of your Tivo at the earliest opportunity rather than having to shell out $40 later. If you upgraded the hard drive then put the original away for safekeeping or at least make a backup image from it. It's best to make a backup using the same size drive as the original. You can always expand the image to a larger drive, but not the other way 'round. There are stickys in the Tivo Community Forums with instructions for making a backup image and restoring it to a new drive.
post #120 of 167 Old 12-28-2012, 12:31 PM
almostinsane's Avatar
Quoted: 47 Post(s)
Liked: 42
Do you not have the original drive available that came with the Tivo?
almostinsane is offline
Reply Home Theater Computers
