how to adjust time on windows media center TV guide - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-27-2012, 03:24 PM - Thread Starter
stevethebrain's Avatar
Quoted: 104 Post(s)
Liked: 25
I'm having diffaculty adjusting the Windows 7 WMC TVguides correct time it seams to be stuck 2 hours early the it says the 6:00pm local news comes on at 4:00pm.
this is what I have done a couple of times to rectifiey the situation unsuccesfully.
Task, settings TV, setup TV signal.
then enter USA, zip code and wait.
I do have the PC clock and date set correctly and it is displayed on the top of the WMC TV guide page.
any tips would be appreciated STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #2 of 7 Old 04-27-2012, 04:41 PM
ghostlobster's Avatar
Wow, that's a weird one! I cannot think of anything WMC specific for that, the only thing that I can think of is the Time Zone setting on the PC itself...confirm you have it set to the proper time zone?
Ray
===Ghostlobster===
ghostlobster is offline
post #3 of 7 Old 04-27-2012, 06:34 PM - Thread Starter
Quoted: 104 Post(s)
Liked: 25
Hello Ray yes having the correct time zone was the solution
I'm wanting a WMC & XBMC remote control, curious why this HP has a IR blaster and a second wired connection what is this second wire for?
http://www.ebay.com/itm/Genuine-HP-O...21879693653687
or hope that the Haupage 2250s (that I'm planning) remote will control
WMC and XBMC
http://www.newegg.com/Product/Produc...82E16815116036
I've read at the XBMC web site this is'nt the best remote for XBMC?
post #4 of 7 Old 04-27-2012, 07:58 PM
WMC and XBMC
Cool about the time zone!
Ok, the second wire there is the blaster that emits an IR signal to control an external set top box. Basically, it changes the channel on your cable box if you're using one. I rely on 2 of those to control my 2 STB that feed my HD-PVRs for my media center setup.
I cannot speak for those products personally...on my main rig I'm using a Microsoft IR receiver with a Harmony remote, and my client PCs use a $20 Adysso (or something like that) remote, which works surprisingly well!
Ray
===Ghostlobster===
post #5 of 7 Old 04-28-2012, 06:37 AM - Thread Starter
Quoted: 104 Post(s)
Liked: 25
Ray can the 2nd wire you say used for cable STB be used for a private satilite STB receivers?
Thanks STB
post #6 of 7 Old 04-28-2012, 08:35 AM
bryansj's Avatar
Quoted: 1130 Post(s)
Liked: 560
Thanks STB
That's what it is there for. Not sure exactly how to make it work since I've never used it, but the HP MCE IR transceiver (transmitter and receiver) is supposed to be able to send the IR channel codes to the STB. Doing this will only allow for one "tuner" at a time and you'll have to figure out how to get the STB's a/v signal into your HTPC.
A tuner card is much easier and allows you to record/watch more than one channel at a time. Plus you don't have to deal with rigging up the IR transmitter.
If you are looking for more info on this I'd suggest not asking in a "how to adjust time" thread.
bryansj is offline
post #7 of 7 Old 04-28-2012, 10:03 AM
Thanks STB
Yup! You can "train" it to control whatever. The Microsoft transceiver has 2 output emitters so it can control 2 STBs. I don't know if the HP has only one or 2, though.
It also needs to be pointed out that nearly all tuner cards only have composite or Svideo inputs, so if you are looking to receive and view HD content, you'll need one with HD component inputs, like the HD-PVR or Collossus (both from Hauppauge and both are excellent withing WMC.)
Ray
===Ghostlobster===
Reply Home Theater Computers
