2 tuners on WMC, but only records what I am watching? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-29-2012, 10:21 PM - Thread Starter
mpovolo's Avatar
This is odd, I have two tuners and recorded a few things today. Then I realized when trying to watch them that it actually recorded what was on the TV playing. Tried again and WMC is only recording what is on the channel.
Any idea why?
thanks
mpovolo is offline
post #2 of 7 Old 04-30-2012, 08:09 AM
Andrew Hornfeck's Avatar
Quoted: 30 Post(s)
What dual tuner card (name/model), or is it two cards? Do they function simultaneously, or is it a hybrid whereby only one can operate at a time? WMC, is that Win 7 or an older WinXP-MCE?
Andrew Hornfeck is offline
post #3 of 7 Old 04-30-2012, 09:09 AM - Thread Starter
mpovolo's Avatar
I use the Huappauge 2250, which has a PCI card and an extension module. Each one is plugged via s-video to a seperate set top box. Running Windows 7 Ultimate WMC, in the setup it did find two tuners. It appears to also let me watch and record two seperate shows. I know this because when I had only one tuner setup, it actually warned me when I recorded something and tried to change the channel. Now with two tuners, I do not get that message however it appears to be recording the channel that I am watching. What is even stranger is when you look at your recording list, the show it taped is listed as the correct show, but when you watch it you notice that it is actually taping the channel you are watching. When you switch channel, that is also recorded.
thanks
mpovolo is offline
post #4 of 7 Old 04-30-2012, 09:17 AM
Quoted: 30 Post(s)
How are you controlling these TWO STBs? What if the IR-blaster is switching both STBs? What if you switch the STB using a hand-held remote, how would the 2250 know? Once you slave a STB to an analog capture device you must assure you're not interfering with it's "open loop" operation.
WHY are you using STBs anyway? What are you trying to record? Go get a CableCard (from your provider) and HDHomeRun Prime or the Hauppauge 2660 CableCard tuner since you're already using WMC.
post #5 of 7 Old 04-30-2012, 09:19 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Never had this problem with mine but it is connected to an OTA antenna.
Maybe what you are trying to record is encrypted but encrypted channels shouldn't even show up in the channel list with this tuner as you need an M-Card tuner for those.
Sammy2 is offline
post #6 of 7 Old 04-30-2012, 09:20 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
That's even a better answer than mine.
You can try to isolate the IR from each blaster to prevent cross-talk.
Sammy2 is offline
post #7 of 7 Old 04-30-2012, 09:33 AM - Thread Starter
mpovolo's Avatar
Hmmm, maybe the IR thing is the issue. I have my two STB's on top of each other with the IR blasters from the 2250 taped to the front of each. It is possible when changing channels that it is in fact changing the channel on both units causing the screw up.
As for the why STB's, I'm in Canada and providers do not allow cable cards. I have no choice but to get the STB from the provider, everything is encrypted and I need the STB to decode then output it into the Hauppauge and into WMC.
The luxury of living in Canada eh! :-)
mpovolo is offline
Reply Home Theater Computers
