Media organisation for XBMC (Program?) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-30-2012, 12:17 AM - Thread Starter
setesh's Avatar
Hey guys, for the most part XBMC picks up media fine. But there is quite a bit its not finding in my library, ive renamed folders (its set to look up from the name of the folder) etc but some just dont find. and theres a few that have downloaded in another language.
Ive used EMBER media manager a long time ago which was GREAT, but it crashed quite often which sucked. And ive used media center master i think it was. when i used WMC instead of XBMC
Whats the best one to use these days?
And how is the best way to go about setting it up with XBMC?
As in the past when i used ember. xbmc re-scanned and re-downloaded stuff anyway.
Cheers guys. I really like the option of manually changing things if i need to like with EMBER
cheers
setesh is offline
post #2 of 2 Old 04-30-2012, 07:52 AM
kneedragger's Avatar
Quoted: 18 Post(s)
What version of Ember do/did you have? Someone started working on Ember again and improved it. You might want to give it another try.
http://forum.xbmc.org/showthread.php?tid=116941
kneedragger is offline
Reply Home Theater Computers
