MKV playback stuck at 23.93 fps - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-02-2012, 10:01 AM - Thread Starter
ohcysp67's Avatar
when i have my gtx 460 custom set to 23.976hz I am noticing that mad vr shows 23.93fps when playing mkv files. Is there any way to get the display to reach 23.976? I am running MPC-HC with madvr. Thanks!
ohcysp67 is offline
post #2 of 2 Old 05-02-2012, 10:09 AM
Matt Malone's Avatar
The MadVR instructions say to use 24hz to play 23.976. That's the setting I use for 23-24 in the MadVR display modes setting. You can also set up MPC-HC to switch to user-defined refresh rates when it enters full screen. Again, I have that setup to play 23.976 at 24hz. There's a program called AutoFrequency that lets you tweak and automatically change your refresh rate as well. I'm also using Reclock, and, though I'm no expert, it seems to automatically play 23.976 at 24hz.
My TV is only compatible with 23 and 24hz (as listed in the Nvidia control panel - I'm using a 470), so playing anything below 29.x at 24hz is the best (and I believe only) solution I have available.
Matt Malone is offline
Reply Home Theater Computers
