Sudden problem with mpc-hc under madvr/lav video - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-03-2012, 09:49 AM - Thread Starter
theod78's Avatar
My setup was playing 1080p@24Hz content without any issues and all of a sudden when I play 1080p files (mkvs) i get numerous dropped frames, on the other hand when I play 720p i get no frames dropped.Is it the last versions of the software (madvr,lavcuvid,mpc-hc) or the nvidia drivers?My display is a Sony 1080p tv capable of playing 23,976
theod78 is offline
post #2 of 9 Old 05-03-2012, 12:16 PM
jriver's Avatar
Quoted: 92 Post(s)
Liked: 75
What changed on the PC?
Jim Hillegass / JRiver Media Center
jriver.com or Owners Thread at AVSForum
jriver is offline
post #3 of 9 Old 05-03-2012, 01:10 PM
JMGNYC's Avatar
Quoted: 51 Post(s)
Liked: 43
MPC-HC with LAV/madVR had been rock solid playing back virtually everything for me until recently where I've started having the same problem with dropped frames. Tracking it down it seems to stem from my use of either DXVA Copy-Back or Native with my ATI card. Very high bitrate BD rips and even 59fps 720p files caused the problem.
If you have a nVidia card try turning CUVID off in LAV video and see if that helps.
JMGNYC is online now
post #4 of 9 Old 05-04-2012, 12:19 AM - Thread Starter
theod78's Avatar
What do you mean cuvid off?Choose different hardware decoder?
theod78 is offline
post #5 of 9 Old 05-04-2012, 10:41 AM
JMGNYC's Avatar
Quoted: 51 Post(s)
Liked: 43
If you open up the LAV Video properties/settings page (not the nVidia control panel) there are some options for it to use CUVID or not.
Check out the Video Decoding section of the first post in this thread.
http://www.avsforum.com/avs-vb/showthread.php?t=1357375
post #6 of 9 Old 05-05-2012, 06:00 AM - Thread Starter
theod78's Avatar
The thing is that I use the same files(mkvs) that previously ran ok and this only happens with 1080p rips.Even if I play 720p x264 rips at 1920x1080@24Hz I don't get any dropped frames
theod78 is offline
post #7 of 9 Old 05-05-2012, 06:42 AM
Alan Winslow's Avatar
In the Nvidia Control Panel located at the Windows Control Panel, if possible change the refresh rate from 24hz to 23 hz.
It worked for me. I was having a terrible stutter with WMPC/MadVR/Cuvid and it's running flawlessly now with the above change.
I am using a GT430 video card.
I hope it helps
Alan Winslow is online now
post #8 of 9 Old 05-05-2012, 11:36 AM - Thread Starter
theod78's Avatar
I hope it helps
But its not a 23,976 related problem because the same time I have dropped frames madvr reports 1 frame drop every 2 or 3 hours!
theod78 is offline
post #9 of 9 Old 05-11-2012, 08:14 AM - Thread Starter
theod78's Avatar
Well I discover something interesting, when I'm using madvr without lavcuvid or DXVA2 native or DXVA2cb I'm getting 0 frames dropped apart from the start of the file.When I pick DXVA2 native or DXVA2cb I get a few!
theod78 is offline
Reply Home Theater Computers
