Buyer's Remorse? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 58 Old 05-03-2012, 09:07 PM - Thread Starter
James_stewart's Avatar
Originally Posted by swarm87 View Post
why did you get a z77 board and a sandy cpu? if i was you id have gotten a 3550k as it has a better iGPU(assuming you'll use it since you didnt say what gpu you're using) the i3 has the 2000 while the new ivy chip has the new HD4000; but agian if you are using a discrete gpu than my point is moot and enjoy
Well that's one of the benefits that i saw in buying this board. If I did decide to upgrade to one of those chips in the future, I could.
James_stewart is offline
post #32 of 58 Old 05-03-2012, 09:08 PM
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
$95.
Did you look at this one?
assassin is offline
post #33 of 58 Old 05-03-2012, 09:12 PM
Zon2020's Avatar
Originally Posted by James_stewart View Post
sorry i looked that wrong one. Yeah I looked at that board. It only has one pciex1 slot and 2 usb 3.0. For $20 I figured it was worth it.
It also has an internal USB 3.0 header if your case has front USB 3.0 ports.
And it has a total of 3 PCIE slots (the Extreme4 has four) which, unless you plan on filling two of them with Crossfire video cards, you're going to have at least two available.
Just curious. What are you planning on putting in all these slots? Lots of tuners?
Zon2020 is offline
post #34 of 58 Old 05-03-2012, 09:13 PM - Thread Starter
Originally Posted by assassin View Post
$95.
Yes! I did. Again for some reason the option for 4 usb 3.0 ports really pulled me in. I'd like 6 total, which is why i'm adding another 2 as soon as I get it.
post #35 of 58 Old 05-03-2012, 09:14 PM
Zon2020's Avatar
Actually you could probably do that even with a $50 H61 board (not that I'm suggesting you go that direction.)
Zon2020 is offline
post #36 of 58 Old 05-03-2012, 09:15 PM - Thread Starter
2 tv tuners, one usb 3.0 card, an FTA satellite tuner card, a possible graphics card, and a high end sound mixing card.
post #37 of 58 Old 05-03-2012, 09:15 PM
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
For what? Personally I have yet to need a USB 3.0 port for anything HTPC related. You can add a 3.0 card for like $14 btw.
assassin is offline
post #38 of 58 Old 05-03-2012, 09:18 PM - Thread Starter
Right now I have 3 external usb 3.0 drives. I plan to add another. I also have usb 3.0 card reader, and I plan to run a usb 3.0 cable to the front of the machine to plug a usb3.0 flash drive.
post #39 of 58 Old 05-03-2012, 09:19 PM - Thread Starter
It feels like my wife is grilling me on why I spent an extra $30 on that silly circuit board.
post #40 of 58 Old 05-03-2012, 09:20 PM
Zon2020's Avatar
Again, what are you using the six USB 3.0 ports for? Other than external hard drives, there isn't much that actually takes advantage of it, and some things that are 3.0 are absurdly priced. For example, I was looking the other day for a simple USB SD Card reader. Micro Center had dozens of them. The 2.0 ones were mostly $5-10, the 3.0 ones were $35 and up. For as rarely as I use it, I figure I can wait an extra 10 seconds.
Zon2020 is offline
post #41 of 58 Old 05-03-2012, 09:20 PM
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
You need a server.
assassin is offline
post #42 of 58 Old 05-03-2012, 09:22 PM
Zon2020's Avatar
Ok, looks like you don't have enough slots.
Zon2020 is offline
post #43 of 58 Old 05-03-2012, 09:22 PM - Thread Starter
I bought a USB 3.0 Rosewill for only $15. Cheap but it should do the trick for large video file transfers.
http://www.newegg.com/Product/Produc...82E16820223118
post #44 of 58 Old 05-03-2012, 09:23 PM - Thread Starter
what is that supposed to mean?
post #45 of 58 Old 05-03-2012, 09:28 PM
Zon2020's Avatar
You need a server.
+1
Or at least a bigger case and some internal drives.
Maybe it's just me but it seems like kind of a shame to build a nice brand new machine like you're building and have stuff hanging off the outside like that on day 1.
Also, with all the stuff you're using and planning to do with this machine, I think I'd go with an i5. Looks like you're going well beyond the normal routine htpc needs.
Zon2020 is offline
post #46 of 58 Old 05-03-2012, 09:31 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
I think it was intended as a joke. I think you probably got the right MB. Now about that CPU... 2500k would have been a better choice, and so easy to overclock for rendering that not overclocking would be the crime. Any chance you can swap for upgrade? But that said, the i3 should already be a lot faster than what you have now.
lespurgeon is offline
post #47 of 58 Old 05-03-2012, 09:32 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
If not a server, at least a multi-bay external line a mediasonic.
post #48 of 58 Old 05-03-2012, 09:32 PM - Thread Starter
+1
You're probably right, and i should have went with the i5. As far as the drives, I like them like that. We went on vacation in january and took a drive with us for two weeks. It was nice to have. I tried putting some movies on a thumb, but that only gave me around 4 movies. The external drive was very convenient. Plus they're hidden.
post #49 of 58 Old 05-03-2012, 09:32 PM
Zon2020's Avatar
Just what it said. I count 6 cards. Unless you already know what's PCI and what's PCIE, and that all 6 will actually fit in next to each other in the six slots (which is questionable) you're already out of slots.
Zon2020 is offline
post #50 of 58 Old 05-03-2012, 09:35 PM - Thread Starter
I may dump the FTA project, it's too time consuming. And I may go with the dual tuner HDhomerun to eliminate one of the internal tuners as well.
post #51 of 58 Old 05-03-2012, 09:35 PM
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
Sure. But you don't need 3.
Not trying to nitpick. Just trying to improve your build.
Alternative you can use Plex. Then you can leave everything at home. That's what I do now.
assassin is offline
post #52 of 58 Old 05-03-2012, 09:38 PM - Thread Starter
If it's anything like slingbox streaming or other streaming applications no thanks. Poor quality, too much buffering, and too unreliable.
post #53 of 58 Old 05-03-2012, 09:41 PM
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
Its actually excellent. You should try it before saying no thanks. Much better and slicker than lugging multiple external hard drives around on vacation.
I watched an episode of Boardwalk Empire while waiting on my plane at O'Hare on Sunday over the Verizon 3G network on my Droid X if that tell you anything.
assassin is offline
post #54 of 58 Old 05-03-2012, 09:41 PM
Zon2020's Avatar
I can understand taking them on travel. When I think I may want more than what I can get on a 32 or 64 gb thumb drive, I just copy what I want onto 500gb pocket sized hard disk.
Have you thought about getting a nice powered hub? Then you only need one port and only have to run one wire to wherever your drives are and you could connect all your drives to the hub there. Since you're not accessing all of them at the same time, it should have no effect on performance.
How do you keep all those external drives quiet?
Zon2020 is offline
post #55 of 58 Old 05-03-2012, 09:43 PM - Thread Starter
Everything is in an enclosed cabinet, ventilated into my garage. Don't ever hear a thing.
post #56 of 58 Old 05-03-2012, 09:46 PM - Thread Starter
you must have unlimited data. one movie would put me over my stupid data plan with AT&T
post #57 of 58 Old 05-03-2012, 09:48 PM
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
I do.
But if you have internet access wherever you go its almost flawless.
Well, except at the Westin. Their internet was awful.
assassin is offline
post #58 of 58 Old 05-03-2012, 09:52 PM - Thread Starter
I do.
Haha. Yes I know all about awful hotel wifi. We actually stay at a cabin in the middle of nowhere. No internet for over 10 days. We turn our phones off for the entire trip and only use electronics at night when we want to watch a movie. It's actually a very liberating trip.
Reply Home Theater Computers
