help diagnosing video issue - AVS Forum
post #1 of 3 Old 05-03-2012, 07:11 PM - Thread Starter
woody777's Avatar
Recently (like in the last week), something in my system has been causing issues. I have no idea where to start troubleshooting. Here's what happens:
- red lines flicker on my display
- lots of digital noise fill parts of the screen (not sure how to describe this)
- display will turn of and turn back on
- display might stay off for a few seconds
- happens in the evening (after the htpc has been on all day)
- sound is not interrupted
- happens during live tv in 7MC (haven't tested much else yet)
- a reboot usually fixes it (until the next day at least)
I'm thinking it's maybe a heat issue and a problem with my GPU/CPU. I'm using an Intel i5 (integrated graphics).
woody777 is offline
post #2 of 3 Old 05-03-2012, 09:50 PM
James_stewart's Avatar
Download Speedfan and read your temperatures. Also remove the cover and keep an eye on all your fans, make sure they're all working properly. Also, if you suspect a heat issue try removing the cpu fan and reseating it with fresh thermal cpu compound.
James_stewart is offline
post #3 of 3 Old 05-04-2012, 06:15 AM - Thread Starter
woody777's Avatar
Does it sound like a possible heat issue with my GPU? I'll try what you said... thanks!
I forgot to mention that there is nothing in event viewer when this happens.
woody777 is offline
Reply Home Theater Computers
User Tag List
