Minimum SSD size for Live TV Buffer + TV recordings - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 05-10-2012, 11:52 AM
kevinmscs's Avatar
Quoted: 477 Post(s)
Liked: 201
Originally Posted by cdru View Post
OP has already stated that he'll archive off content to a WHS so local long-term storage is not needed.
A SSD runs cooler, consumes less power at start up, full load, and idle, and is faster. A single SSD drive large enough for OS, apps, record buffer and short term content storage will provide everything, as oppose to needing (or wanting) an SSD for OS/apps and a 2nd drive for storage.
If you look at everything just most bang for your buck, then almost everything we talk about here is overkill for a HTPC.
Agreed. I'd build an HTPC with a slightly bigger case, eg, not necessarily the "slimmest" case - thus the airflow/fans can do its job to keep it cool, plus the ability to use both SSD and 3.5 regular HDD for storage. Mine - i use the Silverstone GD05B case which is not the slimmest but in my opinion, gives me the ability to put in a regular P/S, any PCI-E card i want (not low-profile) and very efficient cooling...
kevinmscs is offline
Old 05-10-2012, 04:01 PM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
Different strokes for different folks. We live in a tiny apartment and don't have space for something as large as a GD05B (AVR-sized). Most of my HTPCs are the size of the Wii and are hidden behind the TV. Buying a largish SSD for the HTPCs is infinitely cheaper than buying a house (the ones in the neighborhood are in the region of $500,000) or moving to a bigger apartment to accommodate the extra space required.
ilovejedd is offline
Old 05-10-2012, 04:09 PM
kevinmscs's Avatar
Quoted: 477 Post(s)
Liked: 201
Understood. But then when everything is hidden behind the TV, dont you have to buy a RF remote like a Harmony 900 - which is expensive? ;-) j/k
Old 05-11-2012, 11:45 AM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
While the PC is hidden behind the TV, the tiny USB IR receiver is peaking out by the TV's stand. I have no qualms buying a Harmony 900 but the parents prefer the peanut-shaped Media Center Remote. Too many buttons on the Harmony confuses them.
I myself use my iPod Touch or iPhone to control the HTPC.
