Best software for bulk ripping CDs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 05-05-2012, 11:30 AM - Thread Starter
Swampfox's Avatar
I built a box that contains 8 optical drives. I haves hundreds of CDs to rip to FLAC. Anyone know of software that will rip 8 CDs at a time?
Swampfox is offline
post #2 of 11 Old 05-05-2012, 11:45 AM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 913
Eight instances of CDeX.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 11 Old 05-05-2012, 02:21 PM - Thread Starter
Swampfox's Avatar
Thank you.
Works like a charm.
Swampfox is offline
post #4 of 11 Old 05-05-2012, 06:38 PM
Somewhatlost's Avatar
Quoted: 20 Post(s)
Liked: 25
dbpoweramp
  • Secure Ripping: regarded as the securest of the secure, from the inventors of AccurateRip,
  • PerfectMeta uses 5 providers: AMG, GD3, SonataDB, MusicBrainz and freedb,
  • High resolution Album Art,
  • Don't just rip your CDs, AccurateRip them!
NOTE: As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists. so don't take anything I say as advice...
Somewhatlost is offline
post #5 of 11 Old 05-05-2012, 07:21 PM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 913
Originally Posted by Somewhatlost View Post
dbpoweramp
meh. CDeX has decent error correction and is free. Can you even run multiple instances of your forty dollar solution?
olyteddy is offline
post #6 of 11 Old 05-05-2012, 09:05 PM
Quoted: 20 Post(s)
Liked: 25
yep, and it can even work with those robotic loaders/unloaders...
and considering just how crappy the Audio CD spec is (ie up to 20% Bit Error Rate,etc) decent error correction just isn't good enough...
if $40 is just too much for you, then the best free CD ripping option is EAC.
post #7 of 11 Old 05-06-2012, 07:42 AM - Thread Starter
Swampfox's Avatar
Looks promising.
I downloaded it and I'll play with it later.
You can really rip a lot of CDs quickly with 8 drives. It's actually hard to keep up with them!
Swampfox is offline
post #8 of 11 Old 05-06-2012, 09:47 AM
Quoted: 20 Post(s)
Liked: 25
FWIW, No matter what software you end up liking best, the one most important thing is to make sure all the metadata is is correct... metadata is probably one of the most important things, every player/device/etc uses it in one way or another...
it really sucks to get through like a 100 CD's only to find out later that you need to go back and manually fix a bunch of crap...
post #9 of 11 Old 05-06-2012, 01:20 PM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 913
True that. I usually use FREEDB but for the occasional obscure album I use WinAmp and Gracenote.
olyteddy is offline
post #10 of 11 Old 05-06-2012, 02:51 PM - Thread Starter
Swampfox's Avatar
I've done this before, this is just a small part of my collection. Mostly things I bought to fill out missing pieces of my CD collection over the past few months.
I don't know what's "right", but I try to keep the metadata as consistent as possible. I don't understand where labeling the artist as first name last name came from, or worse yet why composer is first name last name, so I change that as I go along. Really do you ever really want to listen to some Wolfgang? Genre can also be all over the map, so I try to make it consistent with my library.
Frankly, I pleased if the song titles are right! I really hate it when some bozo titles the songs Artist-Song name, or has typos in them.
I also loath ripping classical music, almost everything is wrong with the metadata and titles more often then not.
Swampfox is offline
post #11 of 11 Old 05-06-2012, 08:25 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
I've long liked EAC, but it is slow. I tend to use Creative Mediasource because 1) I have it, 2) I've had it for just about forever in various versions), 3) It is simple and quick. I use it because I have an old Creative Zen, but I would not purchase just the software.
lespurgeon is offline
Reply Home Theater Computers
