HTPC buying advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-05-2012, 03:11 PM - Thread Starter
Crisishf's Avatar
I've just won an AMD FX-8120 and would like to use it to replace my old system (AMD X2 5600+, 4GB, Radeon 5770..another win, NSK2480, WD 1TB).
It's only use is for watching movies, TV and the occasional song from the WHS. It will NOT be used for gaming, encoding, etc.
I would like to scale down the size from what I have now. I like the look and quality of Silverstone cases. ITX would be great but I don't think it will be realistic given the processor and its lack of integrated GFX.
Can you give me some advice on a case (plus ODD depending on the case), PSU, video card, SSD and motherboard (no frills required)? I don't want to spend a fortune on this. The current system really does work great for everything I do. I'm just doing this as a fun tinkering project.
EDIT: Forgot to mention support for TrueHD and DTSHD is a must have.
Crisishf is offline
post #2 of 4 Old 05-05-2012, 04:52 PM
winterescape's Avatar
Congrats on your win! This may sound strange, but given that processor and the description of how you will use the system, I would sell the processor and get an AMD A4 or A6 with integrated graphics and low power.
It just sounds like you need to purchase a lot of stuff to accommodate a processor that is overkill for a HTPC
winterescape is offline
post #3 of 4 Old 05-05-2012, 05:51 PM
Zon2020's Avatar
You can build an ITX with a graphics card in a Silverstone SG05 or SG06. Look on Youtube for some build examples. The SG05 looks really nice and some people use them even for compact gaming systems. It comes in both 300w and 450w versions.
Zon2020 is offline
post #4 of 4 Old 05-06-2012, 06:48 PM - Thread Starter
Crisishf's Avatar
Any other suggestions?
Crisishf is offline
Reply Home Theater Computers
