Second HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-05-2012, 07:50 PM - Thread Starter
jefejt's Avatar
I'm picking up a second HTPC. I got a steal on eBay. My first is set up perfectly. Is there any easy way to transfer settings/programs to my second computer?
jefejt is offline
post #2 of 5 Old 05-05-2012, 08:43 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
Probably can't transfer the programs to different hardware but settings and files is easy. You don't say which version of Windows, but there has been a 'Files and Settings Transfer Wizard' in every post 98 version. It's in the Control Panel.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 5 Old 05-06-2012, 06:16 AM
Lars99's Avatar
It depends on what you mean by settings. For XBMC, you can transfer the entire folder inside appdata to your new pc.
Lars99 is offline
post #4 of 5 Old 05-06-2012, 07:59 AM - Thread Starter
jefejt's Avatar
Basically I like the setup I currently have and I want to duplicate it. WMC settings, mediabrowser things like that.
jefejt is offline
post #5 of 5 Old 05-06-2012, 07:59 AM - Thread Starter
jefejt's Avatar
I'm running windows 7 if that matters.
jefejt is offline
Reply Home Theater Computers
