What's more desirable HW or SW decoding - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-06-2012, 05:08 AM - Thread Starter
CountryBumkin's Avatar
Quoted: 218 Post(s)
Liked: 55
Assuming the GPU and CPU (and rest of machine) is capable, and your HTPC software offers a choice, what is the prefered method - Hardware or Software decoding?
CountryBumkin is offline
post #2 of 4 Old 05-06-2012, 05:29 AM
captain_video's Avatar
Quoted: 524 Post(s)
Liked: 341
I'm going to make a wild guess and say hardware decoding is preferable. If the hardware is dedicated to the task it frees up the CPU to do other things. Software decoding requires the CPU to perform additional processing that could be needed elsewhere.
captain_video is offline
post #3 of 4 Old 05-06-2012, 10:01 AM
erickotz's Avatar
Liked: 30
Generally HW decoding is prefferable
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #4 of 4 Old 05-06-2012, 10:54 AM
Acesfullup's Avatar
Easy - it's the same answer to all software questions: it depends.
It depends, but generally, the GPU is better for efficiency reasons. If your CPU and GPU can equally decode the format, then GPU is the way to go since it will save energy and allow the CPU to perform other operations (such as scanning your library in the background, or AV duties).
Although you assumed that your CPU is sufficient, some GPGPU (general purpose GPU) duties are beyond some or many CPUs depending on the software (I'm looking at you MadVR at 1080i60).
On the other hand, some GPGPU code is better at processing the same format and can eliminate issues that complex GPU code can introduced.
There is wide debate on whether CPUs performance will eventually render GPUs obsolete. My opinion is that GPUs are here to stay since there has been a recent emphasis on green computing.
Here is a good discussion:
http://people.virginia.edu/~chg5w/re...eIsTheData.pdf
Acesfullup is offline
Reply Home Theater Computers
