Static when going from full screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-06-2012, 06:47 AM - Thread Starter
mojo_13's Avatar
Been using my htpc for a couple months now and things seem to be going well. Only issue that I am having is sometimes when I try to minimize wmc from full screen the screen goes completely static. I have to turn off the computer and unplug it so that it won't restart in static again. Does anyone know what could be causing this? I have done a search and didn't see anything like this before. Any and all help is appreciated.
mojo_13 is offline
post #2 of 4 Old 05-06-2012, 07:10 AM
bryansj's Avatar
Quoted: 620 Post(s)
Liked: 377
Probably HDCP handshaking issues. You could try switching inputs on your TV and/or AVR to knock some sense into it.
bryansj is online now
post #3 of 4 Old 05-06-2012, 07:47 AM - Thread Starter
mojo_13's Avatar
Ok so that is what handshake is, that come up a few times in my searches but wasn't really sure that was what was going on. I will try to change inputs and see if that works.
mojo_13 is offline
post #4 of 4 Old 05-06-2012, 08:56 AM
bryansj's Avatar
Quoted: 620 Post(s)
Liked: 377
It might be as simple as toggling from one input back to the HTPC's input.
Also, I've solved some handshake issues by minimizing WMC and then restoring it. I just have my remote programmed to send a minimize, delay, restore (start) command.
Reply Home Theater Computers
