150W Pico PSU enough for i3 ivy/sandybridge build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-08-2012, 12:05 AM - Thread Starter
ZenerDiode's Avatar
Thinking of running a fanless i3 build and using the 150W pico psu to power a mATX z77 board, an SSD, and a 5.25 blu-ray drive. Will the 150W be enough?
ZenerDiode is offline
post #2 of 8 Old 05-08-2012, 01:54 AM
dksc318's Avatar
Most i3 Sandy Bridge are 65W and below so should be ok. I have a 65W i5 running on a 72W Thinkpad brick at the moment.
dksc318 is offline
post #3 of 8 Old 05-08-2012, 06:11 AM
killervette's Avatar
I run my i3 with the 80W psu with no issues. I have an SSD but no optical drive. So yes a 150w should do it
killervette is offline
post #4 of 8 Old 05-08-2012, 06:49 AM
SUBCOB's Avatar
I run my i3 2100T, 60G SSD, 1TB WD Green, and a Hauppauge 2250 with a 150W pico. I have had no issues in the 6-months I've been using this setup.
SUBCOB is offline
post #5 of 8 Old 05-08-2012, 08:32 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
i3-2100/H61/SSD/HDD/ODD/tuner card/USB wireless with picoPSU-80 & 72W AC adapter. Max wattage is 50W with Prime95, normal usage 35-40W. 150W picoPSU is overkill .
StardogChampion is offline
post #6 of 8 Old 05-08-2012, 11:42 AM - Thread Starter
ZenerDiode's Avatar
Thanks everyone for the input...looks like I'm going pico.
post #7 of 8 Old 05-09-2012, 02:06 PM
Speqtre's Avatar
Fair warning - the 150W brick that comes with the 150XT kit is huge! I built a very similar system to yours:
i3 2125
Asrock Z68 Mini ITX
SSD
(No optical drive though)
and it only drew 60-70W max.
I ended up buying the 102W brick and using the barrel style plug - the 4-pin DIN connection required by the 150W brick would've meant I had to hack up my case to make it fit, where I already had a hole for the 5mm barrel plug.
Speqtre is offline
post #8 of 8 Old 05-09-2012, 05:30 PM
Quoted: 93 Post(s)
Liked: 160
A good alternative is a picoPSU 120-WI-25 with a 18.5V/6.5A AC adapter. You still have the barrel style adapter but get 120W and come in under the max amperage rating of the picoPSU barrel jack.
Reply Home Theater Computers
