Is my hardware to old? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 05-08-2012, 04:55 PM - Thread Starter
Gary Gleave's Avatar
Quoted: 16 Post(s)
Hi guys
I have a old theater pc powered by a x2 4800 processor, a ton of ram, and a new 6450 video card. I'm using media center XP using this guide http://www.avsforum.com/avs-vb/showthread.php?t=1357375 to set up MPC.
When I have hardware processing enabled, my cpu runs at about 30-60%. When it is not enabled, the cpu runs at 90%.
I'm getting a ton of stuttering either way. I never had this in Theater Tek, or My Theater.
Time for a rebuild, or reformat?
Will my hardware suffice?
I'm also using a RS45 with a DVDO edge
Gary Gleave is offline
post #2 of 9 Old 05-08-2012, 05:15 PM
hirent's Avatar
Your hardware is good enough.
However, I would recommend you upgrade to Windows 7. 7MC is better than XP MC.
hirent is offline
post #3 of 9 Old 05-08-2012, 05:16 PM
DanPackMan's Avatar
Quoted: 232 Post(s)
Liked: 381
I would think your hardware could handle most common HTPC needs, its not much different than mine, but I'm running Win 7 64 bit and XBMC with no other post processing. I think Win 7 performs better than XP on older systems, so you might consider trying an OS upgrade before rebuilding.
If, however, you are like me and just want an excuse to upgrade, then my answer could be changed.....
DanPackMan is online now
post #4 of 9 Old 05-08-2012, 05:24 PM
DanPackMan's Avatar
Quoted: 232 Post(s)
Liked: 381
one more thing..... if you do upgrade to Win7, consider going with an SSD.
post #5 of 9 Old 05-08-2012, 05:46 PM
SteelWill's Avatar
Quoted: 79 Post(s)
Liked: 38
I agree, your hardware is fine, your OS could use updating.
SteelWill is offline
post #6 of 9 Old 05-08-2012, 06:17 PM - Thread Starter
Quoted: 16 Post(s)
Thx guys. Will upgrade OS. If I get win7 to hold me over for now, can I use the same OS in a new build in the fall?
post #7 of 9 Old 05-08-2012, 06:37 PM
SteelWill's Avatar
Quoted: 79 Post(s)
Liked: 38
Might have some trouble if you get an OEM version, they like to lock that to the first mobo it's installed on. Retail should be no prob.
post #8 of 9 Old 05-09-2012, 05:24 AM
DanPackMan's Avatar
Quoted: 232 Post(s)
Liked: 381
You might consider just running a trial version (not entering a key). I think you can get by with that for a few months, certainly long enough for you to see if it is meeting your needs on the old machine. (Google: how to re-arm Windows 7)
post #9 of 9 Old 05-09-2012, 06:40 AM
josrq's Avatar
http://www.bhphotovideo.com/bnh/cont...REG&sku=645759
This is a decent deal on the family pack upgrade. It is not OEM so should be movable to new systems plus you can upgrade 2 additional systems. (Just in case you have other systems on now or in the future)
josrq is offline
Reply Home Theater Computers
