Assassin Server Project - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 116 Old 05-11-2012, 10:57 PM - Thread Starter
assassin's Avatar
Quoted: 82 Post(s)
Liked: 244
Originally Posted by duff99 View Post
Silly question. I assume you tried ReneTHX's fix.
http://www.avsforum.com/avs-vb/showp...ostcount=17409
Actually his post is very similar to the thread that I mentioned here...
http://www.avsforum.com/avs-vb/showt...5#post22009725
I tried this little trick again and guess what?
It worked.
assassin is offline
post #62 of 116 Old 05-12-2012, 06:04 AM
flocko's Avatar
Way to hang in there and get er done
I guess that board goes back to the "recommend" list for server application with a bit of a twist ?
flocko is offline
post #63 of 116 Old 05-12-2012, 10:13 AM - Thread Starter
assassin's Avatar
Quoted: 82 Post(s)
Liked: 244
I think so.
I have created a custom driver now for this thing. I am going to hang on to it.
Might even show up in a guide somewhere.
assassin is offline
post #64 of 116 Old 05-12-2012, 10:35 AM
Tedd's Avatar
Quoted: 933 Post(s)
Liked: 345
Here's to hoping that guide gets listed in this thread.
Tedd is offline
post #65 of 116 Old 05-12-2012, 11:19 AM
flocko's Avatar
I bet not . I think Assassin has mentioned that all the guides are being move 100% to the blog due to forum space limits or something to the effect .
flocko is offline
post #66 of 116 Old 05-12-2012, 12:03 PM
dksc318's Avatar
I noticed you used slot b1 and b2 for memory ???
Or A2 + B2?
Usually the manual for Asus reccomends first and third slot?? Any particular reason you used 2 and 4 ?
When the memory bus signal hits an unterminated open stub such as an unoccupied socket, it will propagate in the opposite direction and create a secondary waveform at any receiver on the bus. Worse case is to have the last slot open because it takes the longest to get to and create a secondary signal that is the farthest from the initial signal.
Usually there are damping on the MB but best practice is still to occupy the last slot.
dksc318 is offline
post #67 of 116 Old 05-12-2012, 06:00 PM - Thread Starter
assassin's Avatar
Quoted: 82 Post(s)
Liked: 244
Had a little more time today.
Awaiting the additional 120mm front fan early this week when it arrives and then the hardware is finished.
Majority of hardware and wire management complete.
4 bay hard drive cage. Rear view.
8 SATA ports occupied. You can see 3 additional SATA cables run and ready to go. All they need is a controller card for expansion.
Upper 5.25" bays. One occupied with a bluray drive and three bays are awaiting additional adapter for more hard drives. Cables (SATA data and power) run and ready to go --- also visible in this pic.
Lower hard drive cage awaiting 3 additional hard drives. SATA power cables run and ready to go.
assassin is offline
post #68 of 116 Old 05-12-2012, 07:50 PM
Fastslappy's Avatar
Liked: 749
Nice!
Mike
JAZZ IS NOT DEAD IT JUST SMELLS FUNNY ; FRANK ZAPPA
Fastslappy is offline
post #69 of 116 Old 05-12-2012, 11:27 PM - Thread Starter
assassin's Avatar
Quoted: 82 Post(s)
Liked: 244
Originally Posted by Fastslappy View Post
Nice!
assassin is offline
post #70 of 116 Old 05-13-2012, 05:57 PM
flocko's Avatar
Nice indeed . A bit of an understatement for me
Man ... what nice attention to detail . Looks like nothing in spending time was spared here .
You've already shared what is left on the hardware side which is an extra fan to cool the hdds . Any thoughts you would care to share ? Such as some initial temps of the system . Maybe squeeze out a thought or two about what is next from you?
Can't blame a guy for trying and I am sure the forum doesn't blame me for trying either
In any case .... REALLY sweet build !
flocko is offline
post #71 of 116 Old 05-13-2012, 06:57 PM - Thread Starter
assassin's Avatar
Quoted: 82 Post(s)
Liked: 244
Initial temps from the system are very good.
I am happy with the build. I can't think of 1 thing I would have done differently. Otherwise I will detail my upcoming plans once I finalize them.
BTW --- The integrated Intel NIC works very well. I unhooked it to do a few tests on my new HD Homerun using that cable so I am using the integrated wireless on the Server right now.
assassin is offline
post #72 of 116 Old 05-13-2012, 10:43 PM
dksc318's Avatar
Who made those nice looking SATA power cables?
dksc318 is offline
post #73 of 116 Old 05-14-2012, 01:56 AM
dksc318's Avatar
Originally Posted by assassin View Post
FYI the Intel integrated NIC (Intel 82579V on this particular board) is NOT supported or recognized by Intel in WHS 2011.
I have been battling this tonight. There are workarounds posted out there but the drivers that they worked with have all been taken down by Intel.
Bottom line: Don't spend extra to get an Intel integrated NIC if you are using WHS as you can't install the drivers --- even manually.
Here is the best discussion I could find on this issue...
http://communities.intel.com/thread/...rt=15&tstart=0
Not worth all this trouble and headache to save $25 and 1 PCI-e lane. Just get a Realtek NIC board and add an Intel NIC PCI-e.
Update: I got it working. See page 3.
I've elected to go with this board with dual NIC:
http://www.bcmcom.com/bcm_product_rx67q.htm
It seems 82579LM should be supported:
http://downloadcenter.intel.com/Deta...=%0ADrivers%0A
We'll see if the driver works for WHS 11.
dksc318 is offline
post #74 of 116 Old 05-14-2012, 06:38 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
I was wondering too
Mfusick is offline
post #75 of 116 Old 05-14-2012, 07:16 AM
RobNY's Avatar
Looks like Monocables.
-RobNY
RobNY is offline
post #76 of 116 Old 05-14-2012, 07:20 AM
bryansj's Avatar
Quoted: 1136 Post(s)
Liked: 561
Why Google Chrome on WHS? Do you have any sort of virus protection installed? I'd consider removing it and reverting back to the locked down IE. You don't really want to encourage web browsing on the server.
bryansj is offline
post #77 of 116 Old 05-14-2012, 07:22 AM - Thread Starter
assassin's Avatar
Quoted: 82 Post(s)
Liked: 244
Because I am also running MSE.
There are definite reasons one would want to access the internet from a server, btw. I have built and designed this server to meet the use of the end user --- not how I would use a server.
assassin is offline
post #78 of 116 Old 05-14-2012, 07:26 AM
bryansj's Avatar
Liked: 561
How did you get MSE (MS Security Essentials right?) to install in WHS 2011?
bryansj is offline
post #79 of 116 Old 05-14-2012, 07:27 AM - Thread Starter
assassin's Avatar
Quoted: 82 Post(s)
Liked: 244
I will detail it in time.
assassin is offline
post #80 of 116 Old 05-14-2012, 07:42 AM
Jackal55's Avatar
That is very nice! And clean! Those SATA power cables are great.
Jackal55 is offline
post #81 of 116 Old 05-14-2012, 11:08 AM - Thread Starter
assassin's Avatar
Quoted: 82 Post(s)
Liked: 244
One more pic today
assassin is offline
post #82 of 116 Old 05-14-2012, 11:40 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
-RobNY
This true?
How much something like that cost?
Mfusick is offline
post #83 of 116 Old 05-14-2012, 07:02 PM
flocko's Avatar
This true?
Only the "Shadow Knows"
Come on ... this is so easy
flocko is offline
post #84 of 116 Old 05-14-2012, 07:11 PM
RobNY's Avatar
I bought some SATA III SAS 8087 cables from them for my raid card and they we price competitive with Newegg and very high quality. Braided cables, nicely labeled and metal locking clips. I'm definitely getting more cables from them for my server project. Oh and I had meant Monoprice cables sorry.
-RobNY
RobNY is offline
post #85 of 116 Old 05-14-2012, 08:33 PM - Thread Starter
assassin's Avatar
Quoted: 82 Post(s)
Liked: 244
Build complete. Being shipped off tomorrow.
A few last glimpses.
And last but not least the Intel integrated NIC and Wireless in all their glory.
assassin is offline
post #86 of 116 Old 05-15-2012, 04:21 AM
funnyfuka's Avatar
are they not sleeved bitfenix molex to sata power cables
funnyfuka is offline
post #87 of 116 Old 05-15-2012, 06:13 AM
csmith's Avatar
Quoted: 46 Post(s)
Liked: 27
Looks like it's going to be a great server system. I've built rack servers, using super mtherbrds with areca raid cards, in the past. Definitely not built for the living room, too much fan noise.
FYI: newegg has the Roswill THOR V2 on sale, for those that prefer a tower...it's huge though, with 6 external and 6 internal 5.25" slots. EMCNEJE56 http://www.newegg.com/Product/Produc...11147053-L018C
csmith is offline
post #88 of 116 Old 05-15-2012, 06:08 PM - Thread Starter
assassin's Avatar
Quoted: 82 Post(s)
Liked: 244
Server shipped today. Should arrive to AVS user on Thursday.
assassin is offline
post #89 of 116 Old 05-15-2012, 06:26 PM
flocko's Avatar
What a lucky member to have been chosen for such a high profile project . I am certain that he / she must be going nuts about right now with anticipation .
flocko is offline
post #90 of 116 Old 05-16-2012, 03:30 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2684
Mfusick is offline
Reply Home Theater Computers
