When I hook up my htpc it doesn't show all of the screen on the TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-11-2012, 09:34 AM - Thread Starter
flyboy320's Avatar
I have a new HTPC hooked up to my 60" plasma. Here are the specs;
Using the HDMI out from the motherboard (GIGABYTE GA-Z68MA-D2H-B3 z68), and a sandy Pentium G620.
AVR is a Denon 591
I set up windows 7 with all updates, and driver updates from the included motherboard dvd. To set it up I used my LCD monitor and once everything was installed, I hooked it up to my AVR. When the HTPC started for the first time hooked up to the AVR, it set the resolution to 1920*1080 OK, but all of the desktop is not on the screen, much of the top and bottom is cut off (with horiz and vert scaling at 0). If I set the resolution on the graphics card to 1680*1050 and set the horiz and vert scaling to 100, then the whole desktop appears correct and I can see everything, but I get a nag screen on the bottom right saying this is not the optimized resolution for this scrren.
Anyone have any suggestions?
flyboy320 is offline
post #2 of 6 Old 05-11-2012, 09:47 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Have you installed all the graphics drivers and intel inteligent management?
Sammy2 is offline
post #3 of 6 Old 05-11-2012, 09:50 AM
jdmag00's Avatar
Sounds to me the picture size is wrong, set to zoom or stretch or something similar.
jdmag00 is offline
post #4 of 6 Old 05-11-2012, 10:01 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I see you did them from the CD. Go online and get the latest ones from intel. You also probably need the realtec audio driver too.
Sammy2 is offline
post #5 of 6 Old 05-11-2012, 10:04 AM
bryansj's Avatar
Quoted: 1127 Post(s)
Liked: 557
Keep the HTPC set to 1080p (1920x1080) and focus on finding the 1:1 mode on your TV. If you listed your exact model of TV you may get more direct answers.
bryansj is online now
post #6 of 6 Old 05-11-2012, 10:56 AM - Thread Starter
flyboy320's Avatar
Thanks for all your help, and fast replies
bryansj nailed it. It was a setting in the TV itself, it wasn't set to 16:9, soon as I did that, I now have the horiz and vert scaling at 100, and the resolution on the htpc set at 1920*1080, and all is good.
Cheers
Reply Home Theater Computers
